whats faster with/without overdrive
Discussion in 'Engine & Performance' started by frank4.6EB992WD, Jun 16, 2005.
  1. frank4.6EB992WD
    frank4.6EB992WD Member
    29
    21
    Jul 27, 2004
    houston
    hey guys i always wonderd whats faster with overdrive on or off?
    whats the diffrence, do they shift diffrent and if they do which
    one will help me take off on the green light the fastes.
    1999 4.6 eddie bauer 2wd
  2. monsta
    monsta Full Access Members
    48
    421
    Nov 2, 2003
    Big Island of Hawaii
    Think of Overdrive as a fourth gear. Having it on or off does nothing for off the line driving.
    Here's some easy reading on the subject. :)
    http://auto.howstuffworks.com/automatic-transmission.htm
  3. EXMAN
    EXMAN Well-Known Member
    50
    49
    Sep 9, 2004
    Cincinnati, Oh
    What's faster of the line.... just about everything on the road except an Excursion. Although, I've beaten a tuner wantabe s-10 and a newer Chevy 2wd fullsize v8. I was pretty impressed.
  4. frank4.6EB992WD
    29
    21
    Jul 27, 2004
    houston
    So with overdrive on im using all four gears and with it off im using only 3, so whats the point of installing overdrive button on vehicles.
    by the way i just took my friends 2003 dodge 4.7 4door 2wd easily
  5. monsta
    48
    421
    Nov 2, 2003
    So that it won't go into Overdrive. That button locks out overdrive.
    FYI, Overdrive in cars/trucks TYPICALLY is NOT another gear. Now on motorcycles is not uncommon for 6th (and sometimes 5th) to be an overdrive gear.
    You should really read that link I posted. It'll really give you a broader understanding on how "automagic " transmissions work.
  6. smo0othride
    smo0othride Full Access Members
    836
    May 26, 2003
    San Diego, CA
    Without getting really techinical, when you have overdrive on it lets you rev higher (more hp in higher RPMS, to a limit), before shifiting into the next gear. So off the line OD doesn't do anything because you still have to accelerate up to the higher RPMS, but then OD will keep it in those higher RPMS so you have more instant power.
  7. stang99x
    stang99x Full Access Members
    60
    Sep 13, 2005
    Overdrive simply give you another gear, which used to be fourth, then became fifth, and now on the newest cars is 6th (new navigator has a six speed automatic) You don't really hear it called overdrive in manuals, however generally its the last gear. 5th in the mustang, 6th in the vett, etc... All it realistically does is allow you to go faster at a lower RPM, conserving gas mileage. Can you think of any other reason to put six speeds in a 7200 pound lincoln? It also aids in emissions somehow, I don't remember exactly but the new mercedes S430 and S500 utilize a six speed, which has really ruined the cars performance, to meet emissions standards for 2006
    One known use is for towing, especially in very steep grades. Notice how when you drive up a hill, slightly graded, that the car will shift up and down and up and down, never finding its happy place? Engauging the overide for autodrive drops it down a gear and "locks out" overdrive, allowing you to operate without constant shifting
Share This Page
