what's up with these headlights
tonydiv
technical advisor
Middle River, MD
It kind of depends on how you want it to work. I would use a relay and then wire it to either the regular headlight wires or to the fog lamps. You could even wire it in to the high beam.
Whatever you choose, I would use a relay to keep from overloading the circuit.
AaronLG
AaronLG
Lubbock
that's weird. you would think they would make it for the low beam headlights.
Remo
Hartford, CT
The reflector uses the regular 9007 bulb for lows/highs. The projector uses a separate 35w halogen bulb that you could run on a separate circuit like foglights.
