kyle_in_rure
Hello all,
I bought a DRL module that is supposed to allow the front turn signals to function as DRLs when the turn signals aren't in use, like some vehicles do. I need to connect the wire supplying power to it to an "ignition" source that has 15 amps available (per the instructions) that will only have power when the engine is running. Is there an easy ( and safe ) place for me to tap into, or maybe an empty slot in the fuse box? I would tap directly from the battery but then they would be on even when the vehicle is off. This is on a 97EB.
Thanks
Thanks
