rtbrjason
This weekend I changed my fuel pump (replaced with new motor craft part) and while the tank was down swapped out the transfer case motor. The old motor worked fine but was almost completely rotted away. Also swapped out the transfer case fluid from a cheap ATF to Mobil1 ATF.
First trip out and it's running fine, 4hi/lo works, but once up to speed I'm hearing a whining noise. It's not too loud, kind of high pitched and the windows have to be down to really hear it clearly.
Any ideas what it might be? It was definitely not there prior to the work mentioned above. Thanks for any insight.
