FordandPolaris
So this weekend was spent changing out the spark plugs in my truck. I did new Motorcraft plugs and Accel Supercoils. I noticed one coil is loose despite the bolt being down as far as it will go. I did not think to give the old coils the wiggle test before pulling them out of there.
The coil is on cylinder 7, which is directly below the fuel pressure regulator on the drivers side. Has anyone had this happen to them? That bolt took me over an hour just to get started due to the regulator being in the way, so by the time I discovered the issue, I was not taking that sucker out to add washers if I did not have to.
The truck seems to run fine they way it is, and way better than it did before the project, so I am inclined to leave it as is, but was curious if others have had similar issues. The other 7 locked down fine and do not wiggle at all.
