jgudnason
Actually FORScan doesn’t have a code update for this function. I’ve tried.
I have the feature, so i haven't tried to specifically enable it, but it is listed in the sheets, values below.
The values match my as-Built with the exception of 726-30-01, i have 0303 vs 0101, so i have an additional bit toggled on in both those spots, but the 1 bit is also on
of course if you've tried all those and not working, i guess it's a no-go. I have read of some successes and failures when it comes to the window feature.
Global Window Open/Close
After pressing lock/unlock on fob, press lock/unlock again and hold button for front windows to go up/down
BCM 726-17-01 0101 0101 014A
BCM 726-17-02 0101 0101 014B
BCM 726-30-01 0101 xxxx xxxx
DDM 740-05-01 Dxxx xx
PDM 741-05-01 Dxxx xx
