Hey how’s it going I have a 04 expy and all the sudden the washer fuild wont spray out I can’t hear the pump running does anyone else have this issue ?
Should be on the same fuse as your wiper motor ( fuse 113... 30 amp...), so if that's working the fuse is Ok. If you can't hear, and it's not spraying, it's probably dead ? They wear out. They're cheap to replace. Do you use a cold temperature rated washer fluid ? If the washer fluid freezes solid it will damage the pump too.
