Your nuts if you think the factory sub amp...
hyfynut
WI
7db is actually about 5 times as loud and will "sound" almost twice as loud to the human ear.
Actually that is not quite true. I suspect you simply mis-spoke.
7db requires 5 times as much power but is not perceived as twice as loud.
10db is considered twice as loud.
10db increase requires 10 times the power.
USMCBuckWild
Camp LeJeune, NC
I agree, my dual 12's work fine. It doesnt kick your ass by any means like an amp putting out 250/channel or anything... but, works good for what it is. Which wires did you use to "bridge" it? As I said, I have dual 12" Kicker comp 4ohm in a sealed box, which wires did you use to bridge it?
I used a IDE 48" power cable for a computer with 4 pins so I could run either my factory amp with the 10" sub when hauling stuff or put in my dual 12's when the 3rd row is down. I got a separate one of an old computer and wired it to my box... Works great!!
I used white/grey stripe for positive and and white/blue stripe for negative.
Keep in mind, I am using a 2ohm SVC 12. That is using 1 ohm per channel (factory is rated at 1.3 ohm per channel at 55watts). If you use a 4 ohm sub and bridge the stock amp it will be 2 ohm per channel and actually REDUCE the output. Most likely to around 75 watts total output. If you use a 4ohm DVC sub, there is a way, with some screwy wiring, to run the amp bridged and reduce the sub to 2ohm.
Adieu
SoCal
But we're not talking about guitar amps or high frequency hertz...I'll make your heart skip a beat and take your breath away playing 20-27 hz
Mr. 10K
Actually, we kind of are
See, the vast majority of tracks out there use guitar and bass guitar, and the rest still use the same frequency ranges - whether its classical strings like cellos or modern synthesizer keys...
MBohn
Lafayette, LA
Your db/watts bit is just a tad off... I work as a DJ, and have 18" subs that are rated at 1,000 watts, and 126db. Meanwhile, my buddy also has 18" subs, also rated at 1,000 watts but only 104db. All depends on the efficiency of your subs and amps. Every time you double your wattage, you will gain 3db. And as someone said, db is no linear, and that is key to remember. A jet taking off is only 24 db louder than one of my subwoofers...
johnboneske
johnboneske
Ohio
Agree 1,000,000.
I used to be a sound engineer. Owned my own sound production company. FOH, i had 4 pairs of JBL 225's with JBL SRX4719's on the bottom, each dual 18" sub cabinet had a Crown 4000 watt amp on it, so 32k strong bottom end and 8k up top total. Sure miss it, but the wife doesn't!
johnboneske
johnboneske
Ohio
also don't forget your subs aren't rated at 126db 1w/1m. Probably more like 100 to 102. 126 is probably topped out at RMS.
