front driver side window is ******* me off
dcarr
stafford ct
i took and sprayed the guides the cables go through too. just kinda worked them up and down while spraying/cleaning the cable
dcarr
stafford ct
all i had in the shed was white lithium grease. has worked for 4 months so far
Miekk
Madison Lake, MN
Has anyone been able to lube the system correctly without pulling the entire regulator out?
4.6 CALIBER
Georgetown
Lots of good info here. I have the same problem when the window goes up. Do yo I need a speacial tool to get the inner door panel off or is there hidden screws?
Miekk
Madison Lake, MN
What year?
Most are philips or 6mm hex screws. Nutdriver works the best. Some are hidden behind covers that need to be picked off with a flat blade screwdriver. After that everything should slide up and out. If it hits the door handle, the bezel around that propbably pops off to allow more movement. If it's 07 or newer, theres also a clip behind the upper speaker. And there's wires attached also...
Regulator replacement or door skin videos are on Youtube or part of the video instructions for your particular year on 1Aauto.com
4.6 CALIBER
Georgetown
What year?
I should have mentioned mine is an 05 EB. Thanks for the YouTube idea I will check the vids out.
ZombieSoldier
ZombieSoldier
Ludowici, Georgia
Don't worry it is only screws and torx bits just like mine. Don't be afraid to manhandle the door handle, it has metal pegs that hold it in place. If it pops out just pop it back in
