removing spark plugs
Buck Nasty
Oregon
I too would like to know. I'm about ready to take the plunge and do it myself. So I take it you got the front six? Did you use a "swivel", u-joint, etc to get the 3rd pair or just a plain old ratchet?
Rumor has it you may have to remove the fuel rails to get to those plugs. I wonder if there's a way around it or if removing/re-installing the rails is easy?
mustangswan
seattle
I use a spark plug socket with a u-joint then a 2 inch ext with another u-joint and another long ext then the wrench. You do not have to remove the fuel rail. They are not that easy, but very do-able.
green03
College Station, TX
i would make sure and blow compressed air into the hole to get any dirt out before pulling the plugs. I go a step further and fill the holes with brake cleaner then blow out with compressed air followed by a little penetrating oil to soak for 20 minutes to make sure the plugs come out smoothly.....
Matt R
Buck Nasty
Oregon
Good tips Matt...Thanks!
.....huh, huh.....he said penetrating. Sorry, I couldn't resist.
2002EB
I've replaced countless plugs in 4.6 and 5.4's and never pulled a fuel rail. P/S reservoir yes, rail no.
It's easier on the 4.6 it seems.
E
ericnj75
neptune city new jersey
today i chose to clean the thottle body so i took it off to clean it. so i changed the plugs while i had it off. man it made life so much easier. took me less then 1 hour to change the plugs,wires and the coils. thank you guys for all your help.
Buck Nasty
Oregon
I got mine done too. Relatively easy to do. All my plugs were thinning out on the prong and looked pretty haggard. Gap is supposed to be .054 and most of them were .070. One was at .090! I also ran a can of Sea Foam through the brake booster. The end result-One smooth running, powerful truck!
