Lowering Kits for 2007 Expedition EL Limited
Hatcher1105
Green Cove Springs
Ok so does anybody know if there are lowering kits for a 2007 Expeditioin EL Limited (non airbag suspension). I can not seem to find one anywhere. So can someone point me in the right direction. Also has anybody seen a lowered 07 EL? Thanks for your help.
eddiemoney
Iowa
Bump from a long time ago. Also looking for lowering springs for an 2010 EL 4x4. Nothing radical, just an inch or two.
stang669
tx
The McGaughy's kit works on a 4wd. I have it on mine and I love it.
Mikes05expy
Toledo, Ohio
Looks good, I like the stance. Now you just get rid of that roof rack lol.
Sent from my Bag Phone using Tapatalk 2
eddiemoney
Iowa
View attachment 5896mcgaughpy's kit and cut coil springs
Looks like some serious camber up front
Lots of questions...to start
How much coil did you cut? Half? Full?
Did you upgrade struts?
Do you have any pictures of the suspension compressed? Intrigued to see what kind of potential interference there is - some of the lifted guys are showing knuckle interference at 3" up...you look about the same down..
SOLISIMO
Ft. Lauderdale
Bro really..... Cut springs on a truck that heavy..... Have u heard of spring rates, that truck will be destroyed within a year. No shock can handle that
Newport News, VA
Look I to drop springs...spindles...even bagging it before cutting springs
Holy Rollerz Christian Car Club (HRC3) National Member
sgtowing
Supporting Members
Valrico, Fl
I agree. I personally would never cut springs
Sent from my Galaxy SIII Using Tapatalk2
stang669
tx
Eddiemoney, I cut 1 coil off the front and 3/4 coil off the rear. The stock front strut is to long for this much drop. I am working on finding the right length. It is a stffer ride for sure.
stang669
tx
New set up for front end. 03 rear struts with same cut front springs. Had to use the 03 spring mounts instead of the mcguaghy's drop mounts. Rides good, not to rough.
eddiemoney
Iowa
Can you get some pictures of some of the angles, suspension clearance, etc under the truck?
stang669
tx
I'll see if i can borrow a friends lift this next week and get you some pics. I need to clean it up anyway after plowing the snow this week. lol
