MoHawk
Yorktown, VA
Had the bull bar finally installed with help from a kind friend. Also got the final new 18in wheel on too. The other 18in wheels are for sale now. They look great together! Pics soon!
Let me see those wheels. And pics of the Bull Bar. I want one so bad, I can taste it.
MoHawk
Yorktown, VA
Also, I cleaned mine real well. Vacuumed the whole thing out, wiped everything down, and hand washed it. Looks so pretty when it's clean.
barigyasi
Alabama
teaser pic of what i finished up on full write up coming soon in my build thread (link in sig)
Blaqjak21
Northeast
Was finally able to do the AUX input mod which worked out great . New projector headlights and HID kit soon to be delivered w/ Projector fogs to follow.
barigyasi
Alabama
Pretty sweet. Lane24 will be jealous haha. Are you putting LED's in as well?
yeah i am, i am currently installing my projectors and trying to figure out how to wire them to the DRL's in the blinker, i know black is ground but idk which other wire is constant when the DRL's are switched on, i really dont wanna splice a wire to figure it out but i might have too haha
Jay87LX
Cleveland oh
Did some body work and started my rocker replacement- Cutting out the old ones and welding 2 new rockers in
FordandPolaris
Saint Cloud, MN
Raptor style LED grille lights-install pics - Ford F150 Forum - Community of Ford Truck Fans
That link will answer your questions. Pretty sure the brown wire was the one I used to splice my lights in.
EDIT: Page 10 on the thread explains the minor wire is in fact the brown, so use that. The rest of the thread is good for ideas though. I used the 10mm bolts from superbrightleds.com that they describe and then some 1 1/2in corner brackets and epoxy to mount them.
KWT2000
NINE MILE FALLS
today i started off fixing the plug on the multi function switch so my turn signals would work with the wheel tilted
then checked the front end expecting to find it needing ball joints and all that stuff and was pleasantly surprised to find almost all the the front end had been replaced recently including new brakes and brake lines, only needs an ideler arm
next i unplugged the drain for the evap core and sprayed the cleaner down the vents and air intakes to get rid of the mildew smell
next we serviced the T-case and did the Brown Wire Mod (works very well)
then i replaced the wiper motor bracket for the rear wiper and correctly installed the lift gate handle, no more rattles back there is a great thing
then i cleaned the throttle body and upper intake it was really bad, and correctly installed the CAI, the heat shield was not bolted down the support bracket was not being used and the filter was not oiled, also cleaned the MAF while i was at it
it didn't have a 3rd row seat when we bought it but i found at a junk yard that was left out side by the pullers pretty dirty, but for $50 i couldn't turn it down a few hours of cleaning at it looks really good
thats all i did today, i still need to service the rear and front diff's and have the tranny flushed and filter changed for good measure and figure out what to do with the front suspension
andrew_s
South of the Mason Dixon
Scangauge 2 install. Took less then 2min including the ripping of the box and I now have 4 pids simultaneously running. So happy to have my trucks vitals so readily available and I get to keep my stock vent for half the price.
Sent from my SPH-L900 using Tapatalk 4
MoHawk
Yorktown, VA
Didn't do nuthin. I didn't even drive it, or even look at it. The weather was to nice to not be on the bike.
Mediamonkey11
Enumclaw, WA
Got rid of the Mach system, installed my 4channel and sub amp, all wiring, Bluetooth deck, and 12" sub. SOOOO much better now!
Mediamonkey11
Enumclaw, WA
where did you mount you sub?
I have the 3rd row folded up and the box sitting in back. It's temporary until I build a box for my L5 15 that'll sit behind the 3rd row. The place where the factory amp and sub were made an awesome stealth install for my amps! I have a cooling fan mounted in the plastic cover for the factory sub, can't even tell it's there unless you listen for it haha!
Lightnig
Behind you
Ok, I just gotta say that this post is just begging for pictures...
I've been playing with the idea of trying to stuff a small (proper) sub enclosure in that space, and seeing if I could get at least one amp in there too. My sub amp would never go along with a box. After all, it's a little over 18" with connectors and cable and almost 8" wide...
