Buzzing sound pass side of engine
cj7_lhc
Lake Havasu, AZ
2002 4.6L with 70,000. After driving for a bit and pulling into the garage I can hear a buzzing sound coming from the spark plug and injector area of the pass side. I also have the autotap engine software and noticed the mv of the same side O2 sensor is erratic. It's not matching the peak and valley of the driver side O2 sensor. So I'm thinking these items are related. No misfiring or other engine performance issues just the buzzing sound. So is the buzzing coming from one of the injectors???? If so how do you diagnoise which one?
Thanks:cheers:
slo-ryd
Ky
You might use some carb cleaner and check for a vacuum leak.
An auto stethoscope would be very useful..
ELVATO
Orlando, FL
The only time I've had any sort of buzzing from the Expy was when a relay was burnt.
z168
Cali
thread resurrected
I thought the buzzing sound I hear was engine related until yesterday when I havent even started the engine and the buzzing sound was there
I have read about a possible relay problem - I will look into it later today. but can anyone tell me more about the PCV valve?
phatbak
Renton, WA
I had loud buzzing from the IAC valve (Idle Air Control), located right behind the throttle body.
z168
Cali
thread resurrected
does anyone have info where the relay is located?
Is it the one in-between the radiator support and bumper?
z168
Cali
I notice a buzzing sound that comes from my oil filler cap. If I hold down the cap it goes away. I wonder if the IAC is causing the vibration to the cap
