Man I thought you were gonna say you got jacked lol.
Sent from my $amsung $III using Tapatalk
Started to change the #3 and 4 plugs and COPS to resolve the 0304 codes I've been getting, but found my hand is too big, my arm is too short, and can't see.
Even after removing the battery, moving the heater hoses and various wiring out of the way I can almost see what I am doing until I get my hand in there. Once my hand is in far enough to almost touch the #4 COP, I can't see anymore and can't actually move my hand enough to actually do anything.
WTF?
What kind of mutant alien was this designed to accommodate to change the rear plugs? I figure if my hand were half as big, with an arm half as thick and twice as long with an extra wrist, had another couple of elbows and a pair of eyeballs on my knuckles, then I could get in there and maybe change the COP...
Can someone please tell me what Ford was thinking?
Since that effort was full of fail, I instead changed the lame 55w bulbs in my driving lights for a set of 100w's. Need to re-aim the lights now, maybe tonight once it gets dark enough.
so, I might end up un bolting that to grab that wire and make a quality splice.
WTF?
ran a new ACC wire to my radio. Ran It from the blu/blk wire from the window switch as it is switched from the acc delay relay. This keeps the radio alive when I initially turn the key off and then shuts it off when I open my door. Used a 5 amp inline fuse and also powered my siriusxm radio with it.
It's all about the extensions... I had to use a boatload of various length extensions and two universal joints to get some of the plugs out.
I pulled the fuel rail and did injector o rings just to make it easier
"did you pull the COP wiring off before pulling the COP?"
Yes, its a two hand stepladder move, and I'm not a little guy. Tie back the heater hoses towards the intake, lean into #4, (clip is on the bottom) left hand pinch the plug with your thumb and pointer finger, right hand long slim common screwdriver to push it off towards the left thumb. Some 14" 90* Neddle Nose would also work.
