cj7_lhc
This 03 expy is my wifes, I don't drive it. She reported the A/C is not blowing from the panel vents. Internet searchs pointed to a vacuum leak. First time I removed the battery and found several vacuum lines coming out of the firewall. Also found the black box vacuum reservoir which is attached to the battery box frame. I used a hand vacuum pump used to bleed brake lines and pulled a very good vacuum on the box. Hooked this up to the small line and was not able to pull a vacuum so I looked at the plastic line again but did not find and damage. So now I'm thinking it's under the dash and I start looking into finding the vacuum lines. That was going to be alot of work so I decided to look under the hood again. Removed the battery and examined the vacuum line again, sure enough there it was. On the inside radius of a bend were 3 very small cracks. Snipped the line, worked a jewelers screwdriver into the boot to break the glue and installed on the line again. Good to go, the wife is happy and all is good.:rockband:
