captain chaos
So, anyone tried re-gearing on an otherwise stock Expy?
Here’s my situation:
I have a 2000 Expedition 4wd w/ a 4.6 and stock 3.55’s. I use it to haul the family on weekends and pull a variety of trailers ( a 12’ utility, 16’ tandem axle car trailer, a 24’ Travel trailer and occasionally a 14’ alum. fishing boat). I suspect that this truck is geared HOPELESSLY tall for anything other than driving unloaded on flat ground with no wind. A recent family vacation trip, with the boat in tow, has me all but convinced to do a gear swap. Even pulling that lightweight little boat it could not hold OD w/ lockup at highway speeds if there was any kind of elevation change at all. Traveling nearly 1800mi with the truck unable to hold lockup on hills in Wisconsin/Minnesota (we’re not taking Rocky Mts. Here!) was annoying at best. We won’t even talk about how it pulls the TT!
Here’s my thought: I’m eyeing a set of 3.90 gears. By my calculations it should put me at 1830rpm at 60mph in OD/lockup. The engine should be fairly happy there under light load and with small trailers. Locked in 3rd it should be spinning a little under 2600rpm at 60 and that should do for the TT. It should have little trouble holding lockup with the camper under normal conditions in 3rd (I’m in Indiana so hills and excessive winds aren’t common problems). I just feel like 4.10’s would have my hwy RPM a bit too high for mpg’s and 3.73’s just won’t be enough to justify the cost.
My biggest concerns though, are over gas mileage. Unfortunately I am not made of money so MPG’s are a big deal for me. I simply can’t swallow losing 2 or 3mpg (10-15%) in the name of ‘peppiness’. My brother re-geared the 03 F150 he had, which had 33” tires, with 4.56’s and he still swears up and down his mpg actually improved from the re-gear . I do believe my mpg’s may go up a little with the TT in tow simply because the little 4.6 labors SO hard with that thing behind it but I’m concerned with unloaded mileage. Currently I get 19-ish hwy (unloaded) and I’m pretty happy with that for a vehicle of this size. I’d hate for that to drop to 16-ish (which is all I could muster pulling that 14’ boat).
I know the right answer is: get a 5.4 but there are a variety of reason for me to stick with what I have, not the least of which is that it’s paid for.
Anyway, anyone re-geared a basically stock Expy? What were you’re results/ thoughts?
