I have a ford expedition 2000 eddie bauer...
xafgoat
california
i recently bought for cheap. currently it rides like a go cart i think the air suspension is totally disabled(suspension light is on). I am curious what my best replacement options are.
JUST4FUN
Admin
Moderator Administrator
Il
have you tryed strutmaster?
strutmastr
ROXBORO
You actually do have a couple different options with the suspension. 1st you can replace the air parts, but eventually you will have problems again, just the way the system is designed. Also, if you ever have to replace the computer, from what I understand, they are no longer available from Ford. If you want to FIX the car and drive it instead of work on it, then visit our website and look at our conversion kits. Here is the link to end your woes:
http://www.strutmasters.com/ford-expedition-suspension-s/76.htm
jakobe
north Ga
air ride suspension switch.
under the dash on the passenger side along the kick plate there is a switch. try to see if that is your problem
