What is this?
98EXPY 5-0
Behind the Throttle body there is a collar on a tube with a red and a blue cover on little tubes. What is this for?
JUST4FUN
Admin
Moderator Administrator
Il
that is the tracking unit that gets instaled on all squad cars
so you dont work on them yourself, now you set off the alarm at HQ:D
98EXPY 5-0
Good. Then the service guy can show up and fix my "miss" problem.
JUST4FUN
Admin
Il
As your looking at the engine in the left valve cover is the PCV valve check it and the plastic hose all the way to the t-body. your looking for cracks in the line that causes vacuume leaks ...Larry
98EXPY 5-0
I'm pretty sure the PCV is on the passenger side valve cover isn't it? I checked the valve itself (it rattles freely) but not the hoses. Would that cause a miss?
JUST4FUN
Admin
Il
YEA ITS IN THE PASS SIDE . MORE OF A PERFOMANCE ISSUE THAN A MISS.
sorry caps. do you have coil on plug?
98EXPY 5-0
Yes Coil on Plug.
I got confused, you said left side valve cover.
I have a post going baout my problem. I am assuming it's a bad coil, but no codes.
JUST4FUN
Admin
Il
ok from your pix its a cop most likly its a coil thats bad
JUST4FUN
Admin
Il
no code. is it due for a plug change?
JUST4FUN
Admin
Il
did you take it to autozone to have the cods read yet? even if the light is off
now it could still have stored codes
davesexplorer
Berrysburg, PA
I dont have those capped lines on my '03.
Our work expedition developed a miss at speed which turned out to be a COP however they replaced the whole set and all the plugs to discover this.
Blackwater
Umm I was just messing with those hoses today. I have two large leaks off of the pcv.
Im not sure off hand on the red one but I do have a hose running off of it. Ill check tomorrow to see where it goes. As for the blue cap I have a hose running from there to right beside my thermostat. From the looks of it at the thermostat end looks to be coolant running in it and was hot to the touch.
98EXPY 5-0
I didn't get to the junk yard this weekend like I wanted to. Hopefully they have a 5.4 I can look at. My neighbor has a 97 Expedition, but it's a 4.6 so I don't know how similar, if at all, their motor would be.
