2015 Expedition Limited Poor Ride Quality
A
Front end is stiff and feel every bump in the road. Wondering if lighter ecoboost V6 required lighter springs or softer shocks? It is the standard wheelbase, not the L version.
montecarlo31
The EB is only ~55 lbs lighter and I am not sure that includes the CAC. that being said 55 lbs is not a whole lot and results in darn near perfect 50/50 weight distribution which is huge for a SUV. The front springs are very stiff at about 698 lbs per inch while the rear are much softer at 230/380.
mreed112
Grosse Ile, MI
Spring rates are meaningless without knowing the leverage ratios of the front and rear suspensions. What is important are #/in rates at the wheel. My guess is that the front to rear wheel rates are much closer.
My 2015 King Ranch is short wheelbase. My ride comfort seems fine on the very rough roads we have in SE Michigan
The lower section height tires on 20 or 22 inch wheels may be causing some of the harshness that you are experiencing. You may also want to make sure your tire pressure are correctly set. I suspect that the main reason the CCD suspension is required with the 22" wheels is to control ride harshness with the low aspect ratio tires.
black 4x4
Los Angeles
Did you guys hear an old saying when you hear a sound hoof look for the horse not the zebra?
Like mreed112 said check the tire pressure make sure it's not set too high and get the alignment checked. Start from there.
Your spring rates shouldn't even be the last thing the worry about unless someone changed them with aftermarket ones.
My 2014 Ford Flex with factory 20 inch rims rides smooth as butter.
Here are some alignment examples.
I had a 2003 Audi A6 got the struts replaced and from the mechanic's shop to alignment shop I thought I was going to lose my fillings. Smallest crack on the road was an earthquake. Once the alignment was done it ride became as amazing as the the first day out of the lot.
Around Christmas I bought new tires for my (now sold 1994 explorer) truck used the rattle like the doors were about the fall off in every pothole. Got new tires and alignment and truck started the drive like new.
Just recently I was in my friend's 2005 BMW 5-Series with stock 17 inch rims and same thing...car was jolting in every crack. Told him that it was his alignment causing that and he argued with me fora minute then let the wheel go and showing me how perfect it was tracking the road I told him that wasn't always the indication, went to the shop got aligned and car started drive like how a bimmer should drive.
All it takes is one good pothole and your alignment is off by couple of degrees and that's enough to ruin your ride.
A
Thanks guys for the input. I did check the air pressure and even lowered it from 35 to 30 lbs and that did help cushion the ride, but started getting feathering on outer edge of tires from it, so went back to 35. I'll take it in for an alignment and hopefully that will fix the problem.
dlcorbett
Air Force
tx
Did the alignment work? Im guessing the ride is different now than when you first got the truck.
Is anyone experiencing poor ride quality in their 2015 Expedition?
I ordered / purchased a 2015 Expedition Limited with the standard 20" wheels, and without the load leveling shocks or optional adjustible suspension.
I now have 2,100 miles on the vehicle. It has an excellent ride quality and I have received several unsolicited positive comments from passengers on how quiet and smooth the ride is. (I live in the Midwest with very poor roads in my area.).
What are your complaints?
A
Our 2015 Expedition Limited with the standard 20" wheels, does have the load leveling shocks I believe in just the rear, but vehicle rides extreme stiff in front and rear. You feel every bump in the road on city streets, but at freeway speed it seems a little less harsh. We also purchased a 2015 F150 Lariat 2wd that surprisingly rides like a Mercedes and is super soft. I kid my wife they put the F150 suspension on the Expedition and I have her soft ride. NOT HAPPY with this Expedition and will most likely be trading it in with less than 4,000 miles on it.
A
Anyone else have a 2015 Expedition Limited standard length with standard 20" wheels and Load Leveling Suspension, that has this ride problem?
k9education
Wow, that's drastic. Out of curiosity, what type of vehicle are you coming from?
rayt
NY
THIS!
American cars will always be lacking something compared to certain luxury brands. Hopefully the OP is not basing ride off a previous car.
montecarlo31
You do realize that your expedition probably weighs 1,400 lbs MORE than the F-150 and probably has an identical carrying capacity so it's going to ride harder, you can't cheat physics!
black 4x4
Los Angeles
THIS!
False!
Not always. I've been driving German cars since 99 and they have their hit and misses too.
I had a 2013 Mercedes ML350 and it was the world biggest piece of crap. It drove like shit and it had a clunk coming out of both sides of the front suspension. And for the life of them MB USA couldn't figure it out why it had it. They even send out a specialist and even he was baffled.
Couldn't wait till my lease was up. Traded in six months before lease was up.
montecarlo31
False!
and now you drive a what?
