Finally did my first oil change on this my new 2010 Expedition. Some notes for you guys:
1) Ford training for its employees must have overlooked the chapter on how to install the factory oil filter. The oil filter on my vehicle was installed so tight that the filter had already been dented by the filter wrench. Then, when I went to remove the thing, the filter collapsed because it was so tight on the receptacle. I considered myself lucky to get it off the receptacle (with much prayer) without tearing the filter body from its base.
The filter had been attached to the receptacle so tight that the oil ring (seal) was crushed/deformed when I removed the filter. I have *never* seen that before.
I would have been madder than a hornet if I had torn the filter off without getting the base off of the receptacle. The $tealer$hip would have either paid for that repair, or taken the vehicle back...
2) Is it just me, or is the FL-820s getting smaller with age?
I remember installing them on my 1995 and my 1999 Cobras, and the modern FL-820s just seems smaller than it was back in the day.
Regardless: I can confidently attest to the fact that the WIX 51592 filter, almost as big as an FL-1A, is a perfect match to the receptacle, and it seems to work just fine. The 51592 fits perfectly in all that space between the radiator and the face of the block, and does make contact with the lower radiator hose - but not enough to cause any concerns.
3) In this configuration, the 5.4L V-8 takes 7 full quarts of oil to refill to spec. I normally put 1/2 quart in the filter prior to insertion, so be advised...
