Running 37's. What to look for?
Texpedition45
I've been lurking for a while and doing quite a bit of reading, but haven't found any good write ups. The inspiration for my Expy is Babysilk's, but I haven't seen any recent posts about his vehicle. From what I gathered, he had a TT/3" with a 3" bodylift, but haven't found the nuances of what comes with running such a massive tire.
So if I'm going to go down that road, what should I be aware of other than I need a bit of lift?
Thanks in advance y'all
jacks3am
michigan
You need gears. Like 4.56 or 4.88s to even have good acceleration. And if you swap gears you will also need a programmer to recal the speedometer. I just put 33s on my f150 and can tell a loss of fuel economy and power. I'm planning on going with 4.10s
Sent from my SM-G920T using Tapatalk
T
Texpedition45
Yeah, I was already planning on going to 4.10's to get some power back, which is what got me thinking about 37s... would 4.56's be enough gear?
What about axles? I'm not planning on rock crawling, but it's definitely not a garage queen. Would the 8.8 and CV's on the front handle tires that heavy?
jacks3am
michigan
Do you have a 5.4 or 4.6? Ide say 4.88s are what you would want, 4.56 is for 35s in my opinion. People run a lot of lift with cv axles and are OK but it will eventually be a weak point, I believe 37 is about the max you want to run on the ifs. The 8.8 I'm sure can handle it but others will chime in with their opinions!
T
Texpedition45
Bumping this for the new guys. Anyone running/have run 37's? The new bfg ko2's are apparently 36.5", and it has my interest piqued. Would it be doable with just a TT and spacers in the rear?
T
Texpedition45
Check this thread out here: http://www.expeditionforum.com/f39/max-tire-size-16559/#post128535
There's a member on here by the name of Thermo who's very knowledgeable on tire fitting and what works. HTH
Yeah, but he hasn't been on in a year if I remember correctly. I read all of his posts before posting this as he kept saying there were a few set of "specific" mods that had to be done, but he never shared what they were.
The other two members who were using 37s on their trucks haven't been on this forum in at least a year as well.
Mediamonkey11
Enumclaw, WA
Interesting I thought he had. Iirc he had mentioned cv shafts would be a weak point, gears, body lift, suspension lift, and trimming. Depending on wheels and what width of tire would determine if you'd need spacers as well. That's all if I remember right...
T
Texpedition45
On the trimming: do you recall what/where to trim?
Mediamonkey11
Enumclaw, WA
Bottom edges of the front bumper and running boards, and whatever manipulation needed to clear at full lock but on the front side I'm pretty sure it hits the swaybar first. I don't remember any issues on the rear but this is all from memory and reading old threads lol
