Daystar lift rear uneven
powerhogger
Houston
I put a daystar lift recently on my 06 but noticed the driver side rear suspension is half an inch lower than the opposite side. Anyone have experienced this with any fixes?
Gruz7
North Smithfield, RI
Coil springs right? And are the shocks new as well? When was the last time the springs were replaced? Has everything been bolted back together properly and double checked? Did you get an alignment done?
P
powerhogger
Houston
Original hardware and daystar adds a spring isolator up top. Reused all the hardware. Checked everything is tight and alignment is done and dialed in
Gruz7
Is it a bolt on spacer kit like what is bolted onto the top of these coil springs?
P
powerhogger
Houston
It's not a spacer like that. Daystar has you unassemble the rear struts to put a taller isolator in replacing the stock one. The isolator sits where the top of the coil spring is. Then the mount is put back on top.
Gruz7
Oh man, don't know if I can be too much help here then maybe it could possible the spring is upside down? Or maybe just something isn't installed correctly I would take tons of pics and compare them side-by-side
P
powerhogger
Houston
Ill probably call daystar and ask em. I talked to a few buddies and they said it's because the gas tank is on that side. But im not convinced
Gruz7
Yeah I wouldn't say the gas tank is the culprit because the normal distribution on the truck it sits even level.. But good idea calling
