What is the best oil to put in the 5.4L 3v
08T1
sierravista, az
Synthetic is better.
Not all oil is the same. Honestly do some research on a oil brand you like compare to other similar brands and go from there. UOA will back up or disprove what's really going on.
Now that I have stopped my oil leak I will start oil testing to help my exp last longer.
In my opinion the cold starts on these things are rough. Every 5.4 I have driven rattles loudly until oil pressure picks up.
JMHO
Gruz7
Gruz7
North Smithfield, RI
JMHO
I agree 100% with the cold start thing you mentioned.... I'm planning to go 7 quarts of Mobil 1 full synthetic and a motorcraft filter for my oil change on Wednesday.....
Due to my lifters/phasers/chain/solenoids (don't know quite what is causing the noise just yet) my uncle is thinking I should to throw a bit of Lucas additive in there... Sounds like a scary idea to me
08T1
sierravista, az
I have put about three cups in my oil. It helped a lot with start ups.
In the past I have stayed clear of oil additives. But the Lucas increased the viscosity enough to help the oil stick. My start ups are noticeably quieter.
I to am running mobile1. Even though it is not a true synthetic. Or in my opinion is not a true synthetic.
I added Lucas because I did not want to increase the oil weight at start up. But I will not know until I get back oil tests.
I am running the 10w -30 now.
Good luck. Let my know what you find in your research.
CJ
Gruz7
Gruz7
CJ
Thanks for the advice and I will! Gotta figure out what my issue is crazy shaking and knocking I hope it isn't time for a motor swap
08T1
sierravista, az
Let clarify the extended life is a true synthetic. Regular mobile 1 is still group 3.
Good luck.
Maloburro
It seems like a lot of people prefer motor craft oil. I have always used Mobil 1 on my other cars. 5qt jugs of extended performance at Walmart are cheap. I like the Lucas stuff too.
xfiles67
Va
I use the MotorCraft Synthetic Blend, also have a bit of a "rattle" at startup, especially in the cold months, have thought about Lucas, reading that some have had success with reducing the noise I'm tempted to try it.
Habbibie
Is it Christmas yet?
Chicago
Guys if you use syn oil make sure you use a syn filter. Putting mobile 1 oil with motorcraft filter bypasses the point of having synthetic oil in the first place.
Fram extra guard
Mobil 1
K&N
Royal purple
Those are examples of synthetic oil filters
Gruz7
Gruz7
Fram extra guard
Mobil 1
K&N
Royal purple
Man I must sound like a newbie... I had no idea they made syth oil filters, I guess I can get a Mobil 1 synth filter at autozone/advance ?
08T1
sierravista, az
Purolator premium and motor craft are the same filter. Both good filters.
CJ
08T1
sierravista, az
Yes the mobile1 synthetic filter in my opinion is very good. Excellent filter and anti drain back is good too.
CJ
Gruz7
Gruz7
CJ
Ok I'll give that a go and see it gets rid of the violent VCT shaking and noise I'm getting
08T1
sierravista, az
Good luck. Plus remember these are my opinions. A good oil and filter combo is the blood flow to a healthy engine.
CJ
Maloburro
Hey Gruz. I'm not sure the oil change will solve your problem. I hope it does. I used to use slick 50 before I ran synthetic. I'm pretty sure zmax is snake oil. Sometimes I still put marvel mystery oil in the crankcase right before I change since it's cheap.
So I use Mobil 1 because about 30 years ago my dad had a Mobil station. I'm sure it was a sales pitch but they showed him the difference between conventional and Mobil 1. Even back then they said Mobil 1 could go
10000 between changes.
I use the extended performance with a Mobil 1 filter now in most of the fleet. I'm not trying to be a fan boy or sell you on this stuff but it's cheap and easy. Usually autozone sells the extended performance and the m1 Mobil filter for about $34-38. Cant beat that if you do it yourself. And I always go 10000 miles between changes l topping off if needed.
Gruz7
Gruz7
Thanks that's what I think I'm gonna do and I think it also won't solve my problem I just want to clean my gunked up VCT solenoids the best I can so replacing them in a week or a so isn't so hard and this will be a trend for me now as I don't believe I can trust anyone to do my oil changed anymore.
Gruz7
Gruz7
Well this stuff isn't cheap haha... Thanks for the help guys I'll be changing the oil tomorrow for the first time with proper oil and then will probably be changing out my VCT solenoids 30a24de793f68193c49ad4527ce8d489.jpg
