What oil/filter do you use?
U
USMCBuckWild
Camp LeJeune, NC
So about 15 years ago, Fram got hammered in several head-to-head filter competitions. They were basically considered "do not use" filters. Has Fram improved since then?
I can not intelligently answer this at this time, but, I will find an answer and get back with you
Habbibie
Is it Christmas yet?
Chicago
I remember that too, that's why I avoid Fram. Cause their standards were low then it tells me that even if they improve they will attempt to take any short cut possible to reduce cost and remain profitable. Same goes to Hyundai and Kia, even though they improved since I'm still stuck with their old ways will eventually come back one way or another.
1955moose
I've been using regular orange body Fram oil filters, in 3 different 5.0 Mustangs, 2 Lincoln mark 7's both 5.0 engines, along with many customers cars. I've never had a engine noise or any issues. In the past I've always used conventional Castrol oil, either 10/40 or 20/50. We never get below 36 degrees in San Francisco. My mileage on these vehicles varied, but my 1982 Mustang went from 89k to 180k when I sold it, with 0 issues. Theirs better of everything out there, but it's one of the cheaper items that I've had no issues with. Been using them for 30 years plus. My Eddie Bauer has been using the pumpkin colored filter for 22k miles, and 5 oil changes. Got a 6 pack of their premium synthetic filters on the way. They got to be better than the basic. In the old days I would hack saw one open, but I drain them and toss them now.
reece146
ON, Canada
I have a Fram filter in the shop (~2 yo) that I'll likely never use. If I get some free time next week I'll throw it in the bandsaw and see if quality has improved.
From what I remember of the problems with the Frams the internals were so poorly made the oil flow circuit was basically just a suggestion and relief valve was unlikely to work in any scenario.
Things must have improved since then...?
Habbibie
Chicago
next time you go to an auto parts store grab a gram XG2 and a Mobil M1-101... Tell me if you feel the difference.
U
USMCBuckWild
Camp LeJeune, NC
I'm going to start a spreadsheet and track everything stated in the thread. No poster names, just specific products so I can research each one and apply findings to them in a manner that is easily understandable and not confusing.
Thank you to everyone for their input thus far!
1955moose
If you guys ever see one of the early British oil filters, they looked like a roll of toilet paper, and somehow they worked. Probably explains one of the reasons the British cars engines failed so early, usually under 100k, and my 240 z went 180k. My Datsun had a spin on filter, and guess what filter I used? Fram orange! When I worked on motorcycles a few years back, we stocked Fram, but with the brand new big bore high performance bikes like Suzuki Hayabusa, and top Hondas, I would stop by dealership and pick up Oem filter. That was on recommendation of people that knew. Their comment was that the Fram didn't have a drain back valve. Being these were first 600 mile services, I didn't want to chance anything. But who knows, without doing one bike with a Fram and the other with a Suzuki filter, and tearing into filter and motor, checking for wear, and debris in filter, we just had to go by faith.
08T1
sierravista, az
Fran has a glued bottom to the media filter. Several have been cut open through the years. The quality of Fram was lacking compared to other brands.
The weight of a filter has nothing to do with quality. Most of the weight attributes to the case thickness and over all size.
Pick an oil based off of your knowledge and personal experience.
I showed that Dino oil has kept my truck alive for 370K miles.
I have run Dello 400 in my 99 PSD. I sold it with 325xxx miles. Current owner has 550xxx miles on it currently.
My father in law had a 96 PSD with 700xxx miles when he gave it to his daughter. Dello400
Take care of your vehicle and it will take care of you.
CJ
1955moose
I've been reading more and more of you guys running diesel oil, with amazing longevity. You can't argue with success. All the oils these days are so much better than what was available in the 1940's through 70's. if they could only build motors and trannys, that didn't break, or strip out.
U
USMCBuckWild
Camp LeJeune, NC
I concur. I ran the diesel oul in a built turbo engine I beat the living bejesus out of daily. It saw 22.5psi and 7k rpm daily and still got 7,500-10,000 miles between services. Fluids have come a very long way.
eluther3
texas
Out of curiosity, why have you fought the urge to go full synthetic?
I have heard horror stories about cars that suffered oil leaks after switching from conventional to synthetic. Word is that the lighter synthetic oil works its way through the seals on older engines that had not previously used it. Given the amount of miles on my engine, I don't want that hassle
1955moose
I think it is true. Switching to full synthetic, does expose oil leaks that were minimal, or non existent before. I guess it's like pressurizing a coolant system with a pump up tester like my Stant. It's going to expose leaks that were only minor before. You want to fix small oil leaks before they turn into big ones. I guess it all depends on your finances, or your ability or drive to fix your SUV.
U
USMCBuckWild
Camp LeJeune, NC
There is truth to this. Synthetic oil,at the molecular level, is smaller than conventional dino oil. The synthetic oils smaller molecular structure not only allows it to better combat shear and breakdown and retain more consistant pressures, it also allows it through smaller/tighter areas. These smaller particles means the "cushion" of oil that the bearings ride on is actually 'thicker' (more oil particles inside the bearing space) than Conventional dino oil. I did notice an increase in wet spots on my Subaru block (205k miles) but no outright leaks. For me, the tradeoff for better internal protection vs minor external oil seepage was an easy one to choose.
The synthetics also have better additives in them that can help fight the leaks of dried out seals. They got a pretty bad reputation for destroying older engines years ago. Modern science has brought fluids an incredibly long way.
ExplorerTom
When I bought my Expedition at 174,000 miles, I started running "full synthetic" (I put that in "" because very few oils that claim they are full synthetic are actually truly full synthetic due to some court ruling on the labeling awhile ago). I have no idea what had been run in it prior. The #4 plug well was full of oil though when I changed the spark plugs right after I bought it, so I know it was leaking prior to me owning it.
No noticeable leaking since I changed the valve cover gaskets.
1955moose
Any oil that can keep your SUV running longer, and smoother, is worth the annoyance of an oil leak. That's why they still sell those sheet metal drip pans at your parts store!
GaryH2
SE PA
Mobil 1 EP 5W 20 with Mobil 1 filter when I do it or Motorcraft semi-syn 5/20 with Motorcraft 820S filter when I'm lazy and let the dealer do it. 181k so far with 5000 mile changes and everything running good.
I've had the oil tested by Blackstone and all indications are that the M1 or Motorcraft does well up to at least 5000 miles. (I say up to 5000 miles because I haven't had any test much beyond 5k - it may be good for longer). Based on the lab tests, it looks like I could go 7500 miles between changes.
U
USMCBuckWild
Camp LeJeune, NC
When I swapped over to synthetic in my Subaru, the car was at 120k miles and it was a little process. Swapped in the synthetic, drove 500 miles and changed the oil and filter. It was BLACK. Ran another 1,000 miles, changed the oil, it was BLACK again. Ran another 1,000 miles and changed, changed the oil and it was mildly dark. Ran 3,000 miles and changed it and the oil literally looked the same as when it went in. Sent sample to Blackstone. They advised 7,500 miles. Ran 7,500 miles and changed oil/pulled sample. The additives were almost the same as a virgin sample, recommended going to 10,000 miles.
Oil always came out looking almost the same as when it was poured into the motor from then on.
Now, I did the transition in this manner because I did not know the health and status/maintenance history of the engine.
Could i have just done 3k interval? Absolutely. My goal was to get the oil clear which means the internals were clear of any gunk and deposits, then take a used oil sample to verify the health of the internals.
Does the transition have to be done this way? No. 3-5k intervals are fine.
1955moose
I've been running Mobil 1 5/w30 for the past 3 oil changes, about 12,000 miles. I didn't notice my oil turning black, or any darkness. I guess both me and the past owner, kept oil clean. I've read that full synthetic like Mobil 1 will stay stable up to 15,000 miles. I personally would not run any oil, conventional or synthetic, beyond 5,000 or so. Regular conventional oil starts to slowly break down after 3,000 miles, that's why in the past they recommended 3k oil changes. Semi synthetics are good out to 7,500 or so. Even if an oil is still protecting, it's the dirt, and contaminants that wear away at your engine. Oil and filter changes when you do yourself is usually under $50.00. Like Pennsoils ad used to say, it's cheaper to change your oil. Get out there and get a little dirty!
