USMCBuckWild
It says 912 in the owner's manual. It is just one one of those two pronged push in lamps. I'm going to use one of the same ones I used for the interior lamps.
I'm not sure what the puddle lamps use on the 17; they used the 912 or 921 on the 05 Expedition.
The license plate lamos are the same as the ones used in the interior.
The puddle lights are a whole different beast. The bulb is sealed in the housing, the housing has to be seperated or cut apart and then wire in an led bulb. I purchased (for alot of money) an aftermarket set that are stock housing that someone else cut apart and added LED bulbs to. In hindsight, I would have done it myself with better LEDs for substantially less money.
