USMCBuckWild
Camp LeJeune, NC
It says 912 in the owner's manual. It is just one one of those two pronged push in lamps. I'm going to use one of the same ones I used for the interior lamps.
I'm not sure what the puddle lamps use on the 17; they used the 912 or 921 on the 05 Expedition.
The license plate lamos are the same as the ones used in the interior.
The puddle lights are a whole different beast. The bulb is sealed in the housing, the housing has to be seperated or cut apart and then wire in an led bulb. I purchased (for alot of money) an aftermarket set that are stock housing that someone else cut apart and added LED bulbs to. In hindsight, I would have done it myself with better LEDs for substantially less money.
Adieu
SoCal
On the right side there is a plastic tab that you push with your screwdriver to release the license plate light fixture so you can change the bulbs.
In this picture you can see the notch where the tab is supposed to be and you can see on the right side the remainder of the tab anchor point.
Unless they changed it since 09, thatscrew looking thing is actually a disposable push fastener, you needa pry toolto yank it and then a vinyl prybar to remove the plate light
No screwdrivers, that would break stuff
Adieu
SoCal
Andy whats the part number for the license plate bulbs? Did you change your puddle lights under the exterior mirrors to? If so what bulb is that?
I'm looking to swap the exterior for LEDS. Not really worried about the interior
Interior front and midrow and license plate lights can all be swapped for like 12 bucks total
Search for JDM Astar 10 pcs Super Bright 194 168 175 2825 T10 PX
On amazon
ExpeditionAndy
Fort Wayne, Indiana
There is a little plastic clip that you use a small screw driver to push to the left and the whole assembly drops down. The socket just twists in and out so you can replace the bulb. In the picture, the tab is broken off. I'll post another picture when I swap out the bulbs later in the week.
Adieu
SoCal
Thats where youre supposed to use the vinyl trim puller
Never use a screwdriver, they break things
ExpeditionAndy
Fort Wayne, Indiana
No, the service tech showed me how to do it using a screw driver like the do in the shop. You only put enough pressure on it to release the clip then you can use your nylon pry bar if you need to.
Adieu
SoCal
Well...your tech showed you yet your brand spanking new clip got broke
Nobody showed me, yet my old '09 clip is still intact and has bright white LED lights now
YMMV, but....
ExpeditionAndy
Fort Wayne, Indiana
YMMV, but....
Whatever. I've been working on cars since long before you were born. It's time to lose the superior attitude Adieu. The clip was defective from the factory. It if you put a couple of ounces of pressure on something, it does matter what you use to push against it. If the plastic is pliable it will bend if it is hard it will break. Once it stops raining, I'll install my LED bulbs.
07xln
Dallas
Ordered a new K&N intake for my 17. Should have it put in by this weekend. Not expecting huge gains but I know it will be better than oem
ExpeditionAndy
Fort Wayne, Indiana
well that's not helpful
I loved my 05. I had 146,000 miles on it when we traded it. I would have had to do cam phasers and timing chains and tune up in about 20,000 miles. It's biggest issue was rusted rockers, radiator support, and floorboards. Since the money worked out we bought the 17 because we travel to PA quite often in the summer and just wanted a newer vehicle.
ExpeditionAndy
Fort Wayne, Indiana
The rockers, floors, core support and timing chains were all just done :favorites37:
I'd say you are good. Just do regular oil changes at about 5-6 K so keep your cam phasers happy and lubricated. One thing to consider is putting in a high pressure oil pump, from what I hear it provides better lubrication for the cam phasers. You can also change the cam phaser solenoids if they haven't been done, that is supposed to be good for the cam phasers too.
Gruz7
North Smithfield, RI
Still having check advanctrac problem... the code leads me to pedal positioning, (I have adjustable pedals) I might make a thread as I've searched on the forum with no luck for the past few days...
Adieu
SoCal
No superior attitude
Broke my fair share of plastics in past, following "pro" advice about screwdrivers...
Went vinyl, issue resolved forever.
