New Led fogs for the 07
gixer2000
gixer2000
Retrofit or Bust
Massachusetts
U got any output pics? Before & after?
My alternator took a dump and stared overcharging so I actually lost all of my led bulbs including these fog light. I have warranty replacements on the way for everything and hope to get the new alternator in tomorrow. Its the original alternator from 07 so it was bound to fail sometime but it was right after I added all led bulbs and these fogs. The ballasts for the hid are still good and all my electronics seem fine, battery cooked and leds don't like 17volts when they are rated for a max of 15 volts. I'll report back soon
gixer2000
gixer2000
Retrofit or Bust
Massachusetts
I really like the look of your dogs and headlights. Did you change your headlights as well or just the bulb? It's hard to tell.
This is a projector retrofit that I built to have more of a stock look. Nothing fancy just quality lighting!
gixer2000
gixer2000
Retrofit or Bust
Massachusetts
Output shots coming tonight! New alternator, battery and fogs are in. Waiting on the rest of my replacement led bulbs and we'll be 100% again
gixer2000
gixer2000
Retrofit or Bust
Massachusetts
Its impossible for me to get lighting pictures right and these do these fogs no justice at all. They are so wide and bright its impossible to capture. I did my best but ill be working on better shots if I can find a better place to get an above shot
Pic 1 like 30' left of the car
Pic 2 I'm showing width, hard to tell but I'm still in the beam here
Pic 3 30" right of the car
Pic 4 is head on above the cutoff line. Also gives a better shot of the width
This was the best I could get for now but ill try to get better asap
funkflex2613
nj
I have these led fogs also i can vouch and say they are absolutely worth the money quality is way better than stock very thick outer lense with metal back housing and lighting is perfect!
ManUpOrShutUp
Hard to tell in the pics what's coming from the fogs. I'm intrigued though.
ManUpOrShutUp
Got my new Morimoto XB led fogs lights installed today. These are an led projector and produce great light output. I'll post up output shots later but I recommend everyone check them out on Theretrofitsource.com
Are these the F150 fogs (which also fit the Expy)? And do they mount up like stock?
