Shimmy after putting on 35s
JoshA77
Bozeman mt
Ever since I put my 35s on my steering wheel has been shaking a lot. sometimes worse than before and it usually depends on the road condition and how fast I am going. I have talked to a couple people who say that's just what happens when you add bigger tires. Any thoughts of what it could be and if I can make it stop?
Connor Clark
Fayetteville, NC
This might pertain but not 100% certain: on my ranger I had a problem similar but when braking. I read to replace the bushings on the sway bar. This did wonders for the little ranger but obviously might not apply to a larger scale vehicle quite as well.
waldo
Miami, FL
I would take the truck to get the tires balanced at a different place and have the coilovers checked. If your shocks are worn you'll start to see a bumpy wear pattern on your tires. I have had my truck on 35s for years without any tire shake but I did put new shocks at the same time as the lift.
JoshA77
JoshA77
Bozeman mt
That may be it. I didn't replace my struts when I did mine. Not sure if I want to do oem struts or maybe shell the money out for king coil overs or something.
waldo
Miami, FL
I went with the ranch quicklifts adjustables and I'm super happy with them, under $660 for all four. Got them set to the 3rd softest setting (it has 1-9) and truck rides very smooth. It also has a wireless adjustment system but I haven't gotten it, yet.
ExpeditionAndy
Fort Wayne, Indiana
Take your tires to a place that does RoadForce balancing. This is different than high speed balancing. They balance the tire and wheel dynamically then they load the tire wheel combo with weight by pressing it against a drum and spin it to locate any additional imperfections. I would do that before you change the shocks coil overs etc. Local shops around here charge about $20 - $25 a wheel. I do that on all of my vehicles and never have any tire shimmy issues.
Vancouver Bob
Vancouver, WA
I've been reading about how a lot of custom wheels have oversized center bores to accommodate many different hubs. Depending on the wheels, you might benefit from a set of hub-centric rings to center the wheels on the hub before you torque the lugs. I've got a set coming for my wheels. Google "hub centric rings" and see what others have to say. May be a cheap thing to try.
JoshA77
JoshA77
Bozeman mt
$664.90 to be exact
https://www.ebay.com/itm/122073163978
well dang! I called the local parts stores and they said it was special order so I had to pay for that plus each strut was like 300... but thanks for the link I might go that route.
Hey VB. Yeah my wheels cam with rings that sit around my hub and they are on there so that was a good thought. Its odd that it only does it every now and then so its not a consistent thing.
ExpeditionAndy
Fort Wayne, Indiana
When that start's happening try turning left or right to get the wheels to spin at different speeds. (so they aren't rotating in the same place, if it goes away, you could have a slightly out of balance or out of round tire.
JoshA77
JoshA77
Bozeman mt
Ok I will try that next time! thanks for the tip!
Tdh777
Pensacola
Definitely not because of the tire size. Have your front end checked, including rotors. Mine shook while braking and I replaced the rotors. Shaking while normal driving could be improper balance or shocks or bushings...etc
