Habbibie
Is it Christmas yet?
Chicago
Anyone knows what this device is called?
I noticed a vacuum leak like symptom today, but while in gear (R, D, 3,2,1) it would idle fine for a few seconds once I come to a complete stop then slowly the rpm dips and the engine would shake more and more until the PCM corrects it by increasing the idle rpm to almost a 1000 from the usual 550, all the hoses to it were dry rotted with holes, I fixed it since but didn't drive it since the fix... Still unsure what it controls or what it is even called. Anyone got a clue?
2005 5.4 3v
Habbibie
Chicago
Update:
Drove fine this morning for the first 10 mins then I get a CEL p2198 p0174, bad idle and drove the rest of the way to work in limb mode. Gonna look into it after work
mike nadeau
Anybody ever figure out the travel in the brake pedal? New rotors all the way around, new booster and master. But I've always had this. My 99 f150 had an adjustable rod that accuated the master cylinder.
06 expedition
MedicMoe
Las Vegas, NV
i dropped my fuel tank to swap out the fuel pump assembly. Noticed that there was no "net on the pump", but I found part of it sucked into to the fuel pump inlet. truck runs way better now!
mike nadeau
Another question.
How is your ac?
I'm here in Phoenix and mine sucks! After new, condesor, expansion valves, compressor seems fine, and the switch to a mark vIII electric fan still only seeing 50's and when it gets into the 112 plus might 70's especially when sotting in traffic. I even had 2 electric pushers ontop of the mark vIII fan at 1 point.
Habbibie
Chicago
Mine is fixed now, didn't have time to drive but idles normally again.
Adieu
SoCal
Night shots of the puddles too! The light output in person is insane compared to stock!!
Dear gawds...i FINALLY understand why theyre called "puddle lights"
Always thought they were just referring to the puny puddle of light produced by the stock version *facepalm*
Gruz7
North Smithfield, RI
Ahaha, yeah I love the led upgrade now you can actually see if you're going to put your shoe into a bunch of water
BaggedExpy
Derby
My 97 had 04 mirrors when i got it. I finally got those puddle lights on and they are brighter then i thought.. i added the ford puddle lights before knowing i could change the dummy lens for turn signal lens. So now i have all kinds of light lol
scoot0073
Georgia
Yeah do u have a link to the Ford Logo LED lights?
I definitely want those.. thanks
BaggedExpy
Derby
Dummy lens? Turn signal? Elaborate plz
On some 03-07 expeditions that have just a puddle light. But if you take a second look the whole bottom piece is removable.( If you pull mirror assy towards body it has a torx bolt holding lens on and a clip behind mirror glass) but Its the same shape of a amber lens. So i went to salvage yard and picked up 2 amber lens and light connectors. My 97 is e.b so had factory heated turn signals so hook up was easy... sorry didnt take pics at time
BaggedExpy
Derby
I had bought mine used. Luckly i was pulling parts of a dude expy and he told me about them. So i had to have them.. when i started looking for them i searched ford puddle light and found them on eBay. But ill see if i can find a good link for ya
scoot0073
Georgia
