DAYTIME BrightLites Puddle Lights
ExpeditionAndy
Fort Wayne, Indiana
A couple of days ago someone posted a link to www.daytimebrightlights.com for LED versions of the factory incandescent puddle lights. They appealed to me and the are supposed to be 20 times brighter. I am not sure how they measure that, but I bought them and they arrived today. Unfortunately I didn't have the time to install them today but I doubt it will take more than 5 minutes each side.
They appear to have a full disk of LED cells that face directly down. I took a before nighttime picture and tomorrow night I will take an after night time picture at about the same time to compare them.
Here are some pictures of the puddle lights themselves. I took the pictures with and without the flash to see if I could bring out any details.
Adieu
SoCal
Andy, to test a 12v LED for brightness, just take a 9v battery (the regular lil household duracell or energizer kind) and touch it to the wires
Theyll be at ~75% output but you can get the general idea and photograph it too --- dim lights will be dim, medium lights will be medium, and a massive freaking spotlight that can light up treetops will still be blindingly bright.
9v will power pretty much any 12v led
ExpeditionAndy
ExpeditionAndy
Fort Wayne, Indiana
That was a great suggestion.
Here are the pictures. I think they are going to be very bright. You really can't tell from these pictures how bright they were and this was only at 9 volts. I have one more Live conference to conduct in about 25 minutes for the college courses I teach. After that I'll go install them and tonight I'll get some comparison pictures to show how bright they are. I think they are going to work out very well.
I found out that they aren't polarity sensitive. It doesn't matter which side you connect to the positive or the negative.
J Ski
3.5plati
VA
Following. I've been looking at these for about two weeks now
ExpeditionAndy
ExpeditionAndy
Fort Wayne, Indiana
I installed them this afternoon it took about 5 minutes per side. The tricky part was you have to start on the locking tab side and pull it down slightly, then you have to pull back toward the locking tab to free the other side. Then they drop right down. Pretty easy. The new ones snapped right in and fit snug. Here are my install pictures.
The truck looks dirty, I washed it but didn't dry it today - water spots.
These are just hanging on the wires in the shade:
Tonight after it gets good and dark, I will post the comparison photos between the stock bulb and the LED.
This one is in full sun.
ExpeditionAndy
ExpeditionAndy
Fort Wayne, Indiana
Okay so here are the results and the juice is worth the squeeze.
Original factory puddle lights with incandescent bulbs.
These are the new ones and I'll post other pictures in another message.
ExpeditionAndy
ExpeditionAndy
Fort Wayne, Indiana
Here are some other pictures of it all lit up. Yes I'm very happy with this modification. The tail lights are still incandescents and so are the front corner lights, I haven't upgraded them yet. I have to turn off the bulb out warning to avoid the hyper flash issue and I haven't done that yet.
J Ski
3.5plati
VA
View attachment 21741 View attachment 21742 View attachment 21743
Got me sold on these! I'll be going to dealer Wednesday to have my bulb out warning turned off for my as I don't have Forscan
ExpeditionAndy
ExpeditionAndy
Fort Wayne, Indiana
J,
You don't need the bulb out feature turned off for the puddle lamps, only if you want to use LED turn signals front and rear. I'm still debating that part myself, although I'm looking at the CariD LED Tail Lights and the Stainless steel trim to put over them - maybe. :D
Newport News, VA
You can simply just change the halogen bulb to led and not spend the money of buying these... if u don't have any puddle lights then ok... that's all I did in my turn signals... enture truck actually... switched to 100% led light bulbs
Sent from my SAMSUNG-SM-G935A using Tapatalk
ExpeditionAndy
ExpeditionAndy
Fort Wayne, Indiana
the 17s have sealed assemblies and aren't designed to have the bulbs changed like the earlier versions. You could go and cut the lenses off and try to retro fit an led. These assemblies are $71 each from dealer and you can get pair of the LED ones from BrightLites for $60 with shipping. These have a round LED disk inside which spreads the light and and throws a lot more than a regular LED bulb will do. I know because I changed out the Puddle lamp bulbs in my old 05 with LED and they were brighter but not as bright as these. Look at the comparison pictures a couple of posts up. Big difference.
John Christopher
CT
This is a great thread on the lights. Thanks for posting.
Andy you are correct on my 07 I looked into it and I could not replace the bulb it was an entire independent assembly that just had plugs on the end and was sealed.
ExpeditionAndy
ExpeditionAndy
Fort Wayne, Indiana
In a sense if you have the right tools, you can probably take it apart and modify it and put it back together. It might be fun, but for $60 delivered with these results It made a lot of sense just to buy them. The only way you can make anything you modify this bright, would involve looking looking for and finding the round LED disk they use in these.
bloodhound
Merica
I posted the link to these in the other thread, but had never actually purchased them. Thanks for being the guinea pig Andy, I'm doing to get them now!
ExpeditionAndy
ExpeditionAndy
Fort Wayne, Indiana
Thanks for posting them Bloodhound. They were a great find. I am really enjoying the light from them. I may order a pair for my Wife's 2017 Escape. :D
Adieu
SoCal
Wrong you can definitely take them apart it has one of those festoon type bulbs inside...
Nope. Wrong. Fake news. False. Unless your truck has aftermarket knock off lights. My OEMs were sealed units.
