AWD actuators making noise 2008
William_ff
Westminster
The front AWD actuators aren't fully engaging or disengaging. I found some stuff relating to the F150 and it seems right on with the actuators themselves, but I can not find the vacuum solenoid. Also the symptoms are slightly different. Here is the scenario.
In 2WD start driving and get the noise.
Switch to AWD noise goes away and then comes back.
Switch to 2wd noise stays, switch to AWD goes away and comes back.
Also while in 2wd with the noise, switching to cruise control it goes away and comes back.
From the F150 stuff I've seen it is more set than this. Since it can go away and come back seems it might not be the AWD actuators themselves but the thing controlling them.
Thanks,
Will
deweysmith
Montreal, QC
On the 3rd-gen the solenoid for the vacuum-actuated hubs is on the firewall above the brake booster on the driver's side. I would bet you have a vacuum leak or a bad solenoid. I think the hubs are unlocked with no vacuum, so it's probably a bad solenoid. It seems that it can pull vacuum for a second or two to lock the hubs, but the vacuum leaks down after a while and it partially unlocks again. The noise might be caused by the solenoid not closing fully either, allowing a little bit of vacuum down to the hubs so they are always half-locked.
I dunno a ton about them though, other than where the solenoid is.
W
William_ff
Westminster
That is the solenoid that is named Canister Purge Solenoid / Purge Valve, right? The one for the F150 is called Solenoid, 4WD Engage And Emissions Purge or IWE Solenoid.
So the Canister Purge Solenoid / Purge Valve is what I should replace? Just confused on the names.
W
William_ff
Westminster
I disconnected the hose from the solenoid and nothing changes. It is like it has nothing to do with the system.
deweysmith
Montreal, QC
This is the electrical diagram for the engine compartment in the service manual for my 2012. You can see the electrical connection for the solenoid in ~C6 in the grid, I circled the label. It's called the Integrated Wheel End Solenoid in the manual.
Again, this is on a 2012, 2008 should be similar.
The Canister Purge Solenoid is part of the EVAP system and lives right behind the intake on my truck, you are correct that it is entirely unrelated to the 4WD system… It's connected to the vacuum system to pull fuel expansion vapors from the gas tank and push them through the intake.
W
William_ff
Westminster
I found another vacuum solenoid around there, but that isn't it either. I can't even find a part for an 08. I only can find it for up to 06 and then nothing at all for an 08.
Example: https://www.1aauto.com/4-wheel-driv...MI6K2hx_Tk1wIVlArTCh3l2AOIEAQYASABEgIPcvD_BwE
Vehicle Fit
  • 1997-2006 Ford Expedition 4 Wheel Drive Engage Solenoid
  • 1995-1996 Ford Explorer 4 Wheel Drive Engage Solenoid
  • 2004 Ford F150 Heritage Truck 4 Wheel Drive Engage Solenoid
  • 1997-2013 Ford F150 Truck 4 Wheel Drive Engage Solenoid
  • 1997-1999 Ford F250 Light Duty Truck 4 Wheel Drive Engage Solenoid
  • 2006-2008 Lincoln Mark LT 4 Wheel Drive Engage Solenoid
  • 1998-2006 Lincoln Navigator 4 Wheel Drive Engage Solenoid
deweysmith
Montreal, QC
Here is the part listing on fordparts.com for a 2008, which includes the exploded diagram.
How did you determine that wasn't it? You should see two hoses coming from it, and they end up at the wheel hubs. It's possible that you have a bad hub, too. Simple test, do the hoses on all ends of that solenoid hold vacuum when you suck on them with your mouth? They're dirty on the outside, sure, but they should be clean on the inside. :) If they do, it's not a leaky hose, and it's either a bad hub, or a bad solenoid. It could also be low engine vacuum but you'd surely have other symptoms aside from this.
deweysmith
Montreal, QC
Check out this video from FordTechMakuloco. He explains how to diagnose it… The only difference should be that the solenoid is on the driver's side, not the passenger side. It's behind the coolant bottle and the brake fluid reservoir. You can see the same hose connections and check valve in the video connected to it, and the part number on the solenoid on mine is 9L14-9H465-BA. Here it is on mine:
Also, I was wrong. Vacuum unlocks the wheels, there's a check valve there to maintain the vacuum and keep the hubs released, even when the engine is off. Try the video's method, bypass the solenoid entirely and see if the clicking stops. Try as the video suggests, disconnect the hoses, and attach the hose that goes to the hubs directly to the check valve and run the engine (go for a spin, even) and see if the clicking stops. If it does, bad solenoid. If it doesn't, bad hub.
W
William_ff
Westminster
I do not have that. I have something similar right there and it always has a vacuum on the hose and on the other side of the solenoid. I think it is the brake booster. I will go take a picture.
W
William_ff
Westminster
The top solenoid is the evap. The one to the lower right of it always has a vacuum going through it.
deweysmith
Montreal, QC
Weird. I bet yours is over on the passenger side, then. So strange, because the 4x4 system was supposedly unchanged through all of the 3rd-gen, even since 2004. I guess moving the solenoid doesn't count.
If that's the case I'd bet actual dollars that you have the exact problem that is going on in the video I linked. The solenoid gets wet easily since it's near the windshield drip area and the water gets in the vacuum lines and makes its way into the IWE and destroys them. Give the video a watch and see if you can find it.
W
William_ff
Westminster
Ok I traced it and found it to the left of the fan shroud. This must be because the location on the firewall has the parts for the special service vehicle lights and such. Maybe it isn't on the driver's side because of the brake booster or whatever is there that isn't in your pic. Maybe the brake system is better on this vehicle. I'll do the bypass and let you know the results.
deweysmith
Montreal, QC
IT'S AN SSV?! Yeah those are their own mythical beasts.
Awesome though, looking forward to hearing what you find.
W
William_ff
Westminster
I unhooked it and there is still the noise. I bypassed it for full vacuum and the noise goes away. So in terms of the suction it fixes it. I wonder if the noise is full engagement but the teeth are already bad at this point. So I am going to replace the solenoid to see if it works fine in 2H and test further and then look at the actuators.
Thanks for the help!
deweysmith
Montreal, QC
I'd bet it's the solenoid. Real easy to check if they're locked, lift up one wheel and spin it and see if the CV half-shaft spins too. Since the problem was still there when you disconnected the vacuum lines, it seems everything else is in fine, the solenoid is probably stuck half-open so it only ever gets partial vacuum pressure.
The teeth on the IWE are designed and built softer than the teeth on the axle so they wear faster because that part is easier to replace and cheaper than a CV axle, so even if they are busted, it's not too bad.
W
William_ff
Westminster
Has been driving great in 2H now. Any thoughts on the Motorcraft vs aftermarket part for the actuator?
deweysmith
Montreal, QC
I have been putting Motorcraft everything in my truck but I don’t think it would hurt here to use an off brand. Usually the price difference isn’t huge.
Frank Wilson
PlymouthMA
For the past 1.2 years I have been having the AWE sound, but only when it's cold out. Is it possible the solenoid is sticking in sub 50 temps? The hubs vacuum with a manual pump and guage , so I figured my first winter was a fluke. But it's happening again now. Turn it to 4A and the sound is gone. Turn it to 2w and the noise starts after a period of time, usually when I coast. From what I understand, WOT is when the stored vacuum is required, but, this is the opposite of that. Engine has 102k ( probably much less with th on it, maybe it's too old now and I should put her out to pasture. But I spent a bunch on her in purchase and shipping from kansas ( ebay)
Bought it with 95k, love her, she keeps my kids safe.
I just don't know if I made a mistake. I change the Oil too early (4k) , and there is now a bubble paint point at the licence plate chrome contact points.
I called a car donation group, and they offered tax papers and purchase cash a 17th of the purchase price.
It also has rust on the roof.
