WhoaTed
Hello all, I’ve found answers to other questions on the forums but I haven’t found any advice on the following; 2017 Platinum EL 4x4, 147,000 miles:
Especially after cold start, when moving either forward or reverse, in gear, moving slowly 1-10mph with wheel turned left or right there’s a heavy binding sound/feel coming from the drivetrain; very little if any thru the steering wheel. Once it’s moving the sound/feel stops if I take it out of gear while it continues to slowly roll, returns if I put it back in gear. Straighten the wheel, it goes away. Nothing at higher speed.
This has been happening since I bought it 15,000 miles ago, dealer thought it was hub actuators. Does feel a bit like it, but doesn’t change at all when AWD is actuated but I replaced them anyway having done it before; I only mention it for reference, it’s not the problem. AWD on/off including low doesn’t affect it, it does resemble the normal 4x4 low binding but the binding doesn’t increase the more it moves and again, only while turning. Again, The front hubs work fine, they are not engaged.
Butt feel tells me it’s coming from near the front of the driveshaft/transfer case/transmission area; all have proper clean fluid & good u-joints. I’m very good at mechanical diagnostics & know which end of the wrench goes on the nut, I can usually figure this stuff out but this one is laughing at me. Anyone?
