ExpeditionAndy
Well the chart here shows the actual starting pressure which is based on the weight of the vehicle and the load bearing weight of the factory tires, for example if the factory tires are set for 2450 lbs each then you add pressure until the LT tires are pumped up enough to support that weight.I think maybe you meant actual load, not load capacity?
This is turning out to be more complicated than I thought now that I'm really thinking it through and looking up charts for my tires etc. Who knew tires were so complicated?
This article isn't specifically for LT tires but seems to hit the topic hard.
https://www.4wheelparts.com/tire-wheel-package-guide/tire-pressure-checker.aspx
One aspect of the idea seems to be to achieve the proper tire/road contact area for wear etc. I noticed as I increased the pressure today to 44 psi, much less of the tire was "touching the pavement". But I don't really know how much should touch so ??? Now I'm going to be looking at everybodys tires in parking lots for the next week! I was doing that at Wegmans today and a nice lady stopped to make sure I was OK. She thought I had fallen. It almost worked out great for me! LOL
Also interesting discovery was finding out that one tire was down to 22 psi when I started out. This is with the new install last week. So I guess I might a slow leak and need to monitor. Or maybe the tire shop failed to inflate properly? Will monitor that and find out.
I found the chart and quote it here: http://www.expeditionforum.com/posts/281108/
Stock tire size is P275/55R20, which is load rated at 2403 pounds at 35 PSI in a passenger car application. Since it’s on an SUV, you divide that by 1.1 due to downrating of P-metric tires in an SUV/light truck application. That gives you 2,185 pounds at 35 PSI.
The tire he is replacing it with is an LT285/65R20, which supports 2,180 pounds at 35 PSI. At 36 PSI, it supports 2,222 pounds. Thereby putting it slightly over the requirement for this application.
This info all came from the Tire and Rim Association Load application tables, which is the standard used by all tire and rim manufacturers in the US to rate their respective items.
I wanted to put this out there because there are always a lot of questions about how you truly determine proper inflation for an LT-metric tire in an application originally fitted with a P-metric one.
