Lift Kits for 1 Gen Suggestions?
acolic
Hamilton Ontario Canada
Hi,
I'm looking for a 4"-6" lift kit for my 99 Ford Expedition.
I've found a 1999-2002 4WD Fabtech 6" Performance System K2006 lift kit on eBay but at $2500 that's a bit tough to justify.
Any other kits out there?
Thanks for the help,
Alex
A
acolic
Thanks I saw those kits but they rely on replacing the torsion keys which I heard was a bad idea?
Something about added stress on the torsion bars.
Have you used this kit? Any concerns?
On another point the kits indicate they are only for 4WD expeditions, would that be the same as an AWD expedition?
ExplorerTom
No such thing as an AWD Expedition. You have a4wd. Similar, but different.
I got their rear spring spacers and cranked up my factory torsion keys. Replacing the torsion keys allows you to crank the torsion bars higher- which effects the ride even more. Their claim about "maintaining ride quality" is totally bogus. Plus more lift like that puts more wear on your CV joints.
I'm happy with the amount of lift I got. I fit legit 33s (they almost round up to 34) and the ride quality is still pretty good. I think the overall visual proportions of my Expedition are perfect now. Click the link in my signature to see more.
Texpedition45
Hi,
Alex
No.
If you're looking for out of the box, that's it.
Or,
You can buy a Rough Country lift for an F150 (4"), lift the front suspension, and find longer springs somewhere else to lift the rear 3 to 4".
Realistically those are your two options for a suspension lift.
The rest would be a combination of body lift, reindexed keys, spacers or longer springs for the rear, and playing around with shocks to get the ride you want.
Joseph Burgess
Georgia
Good question where does the rear coil spacer mount, on top of coil or on the bottom, the daystar ones look like they go on top but I’ve seen others that look like the go under them , any help would be appreciated
ShillyDilly
MD
Did the Supreme 1-3 inch front with keys and 2 inch rear spacer. Didn't even have to crank the torsion bars much. Definitely puts the cv shafts at a bind, working on a solution for that now. Other than that it's the best kit for the $$$ imo
Allowed me to fit 33's on my 2000 EB with a bit of plastic trimming on the bumper
