Any reason not to drive with auto 4wd on full time?
Boose
2017 Platinum EL
NJ
I know enough to be dangerous, no expert ... barely head above water on this and many other topics.
BUT there is a WIKI page on this ...
https://en.wikipedia.org/wiki/ControlTrac#The_Modes
and this quote from the WIKI says the opposite
of what you typed about 4Auto above?
So I disagree. if I'm wrong , forgive me ...
Auto mode was featured on both Explorer and Expedition and allows for all-weather, full-time four-wheel drive capability on pavement as needed. In Auto mode, the engine’s torque is normally routed to the rear drive wheels. A misconception about the system is that it continuously shifts into and out of four-wheel drive as needed. This is not true, for when Auto mode is selected, the front axle hubs are permanently engaged, locking them to the front axle shafts, front differential, and front drive shaft. This is so the front drive shaft always rotates (turns) when the vehicle is being driven at speed. The computer control system needs the front drive shaft to turn, so that it can monitor and compare the rotational speed of both the front and rear drive shafts. If the rear drive shaft starts to turn faster than the front, the system interprets that (along with input from other sensors) as traction loss. When traction loss is detected, torque is sent forward to the front differential in 10 percent increments, via the center multi-disc clutch. As it does so, intelligent control software allows the center multi-disc clutch to behave like a geared center differential, such that "driveline binding" and "torque windup" do not occur. The transfer of torque is done in secrecy, virtually undetectable by the occupants of the vehicle.
In the early 2000s, ControlTrac was updated and introduced in 2002 with more advanced software programming, building on the system’s artificial intelligence.[8] The four-wheel drive system's updated artificial intelligence allowed the system to predict traction loss before it happened, so that torque can be transferred before it was needed.[7][8] This improvement meant the system could operate more like other "always-on" full-time four-wheel drive systems as it no longer had to "wait" for traction loss to take action.[8] Another improvement was front-to-rear "torque biasing" capability in Auto mode. ControlTrac's intelligent multi-disc differential could now send all 100 percent of the engine’s torque forward, biasing it to the front differential if severe traction loss was anticipated, predicted, or detected.[8]
Good stuff! I have only had my 2017 since mid December, only needed the 4WD once or twice this winter. I distinctly remember in my 05 a noticeable shift when in 4 Auto. Not sure if it was the Transfer case, or the hubs engaging. There would be a slight slip, then the front axle would engage. I'm sure the system has been refined from 05 to 17. This definitely explains why when I took the 17 out the first time in the snow, I felt absolutely nothing when in 4 Auto. Just smooth, confident traction :)
In my 07’ you can’t hear or feel anything you just know because in 4A you can gas it pretty good and it still won’t slip out like in 2H.
Boose
2017 Platinum EL
NJ
Now I'm wondering if there was something not quite right with my old truck... Maybe someone with an 04-06 can confirm what theirs is doing...
Boose
2017 Platinum EL
NJ
I think this is the article from Design News that got me to buy my first Expy.
https://www.designnews.com/automotive-0/4-wheel-drive-steps-back-future/143802243139748
in other news , its still snowing here!!!!
WTF
This makes sense:
"Called Control Trac by Ford, it acts as an automatic form of four-wheel drive. Using sensors, microprocessors, and a specially designed electromagnetic clutch, the unit quickly switches from two-to four-wheel drive when it senses wheel slip."
That is what I experienced... granted, this article was written in 1995. My 05 would take about a half of a rotation of the rear tires in order to engage the front axle while in 4A.
This makes sense:
Our 3rd gens have the ControlTrac II system.... your 05 was a 2nd gen and may have had the first ControlTrac system.
Black
Kentucky
My 02 Explorer had the same system just no factory option for 2wd.
4x4 Auto was the default setting could switch to 4H and 4L.
You knew when the fronts were engaged. It wasn’t an awful feeling or awful noise but nowhere near the quiet and smoothness of an AWD system.
Though for off-road capabilities the AWD will not perform as well as the 4x4.
In snow even moderately deep the AWD system shines. My 2001 Audi A4 Avant Quattro was flat amazing in the snow. Really deep snow was a little rough as I had it slammed pretty good on Koni coilovers.
Our current 2012 Highlander with AWD way outperformed my 2014 Tacoma 4wd work truck in snow but of course the backend weighs nothing. It still got where I needed to go just a bit more tail slide than the Highlander. Mountain roads and down in the hollers I’ll take the Tacoma of Explorer for sure. I predict the Expedition will do just as well.
Looking forward to getting the Expedition off road a bit some here soon to see what she’ll do.
Muddy Bean
Oh and I also disable traction control a lot. So when I get all tire chirpy, the truck doesn’t yell at me. And I’ve seen some of you mention in other threads that you almost never floor the throttle on your truck???
Seriously?
[emoji849]
bobmbx
Seriously?
[emoji849]
I think I've done it once.
BTW, my babe is an asphalt queen. Doesn't like to get her toes dirty.
oldpaddy
oldpaddy
Cape Cod
Seriously?
[emoji849]
Only during the summer when I'm blowing past a tourist who's going 30 in a 45.
deweysmith
Montreal, QC
Nope. ControlTrac II was only ever used on the Explorer and has since been replaced with Intelligent 4WD. Expedition continues to use the same ControlTrac system it has always used, albeit with some updates.
It’s just that good.
ControlTrac II used a viscous coupling instead of electronic clutches and it wasn’t nearly as successful. ControlTrac has won numerous off-road races and competitions and the like.
