Ouch. Tad harsh there, my friend!
Yea that was harsh, sorry I was pretty pissed off yesterday regarding an unrelated subject and took it out on my fellow colleagues instead
The Mobil One was on sale at Costco and I got the filter for cheap at Farm and Fleet. Maybe It was under $30....still a good deal.
That is a great idea. I changed my oil a few weeks ago and oil from the filter dripped everywhere. I cleaned as best I could with brake cleaner but the next morning I had a small pool of oil about 1 inch wide on the garage floor. I verified that the oil filter and oil pan plug were not leaking.
I think the zip lock bag idea will help the next time I tackle this. Thanks!
And now that I know how/what to do it won't take me as long next time. Now that I know how to 'contort' my 70+ year old body to get at stuff.
Not sure if everyone is aware of this or not ,but if you twist those white plastic fasteners on rubber blanket that’s up front under drivers side, then it will flap down so you can access the oil filter from there. No need to remove metal pan for access, just the rubber trap door for oil to drain out through.View attachment 26046
I installed one of these on the oil pan https://www.fumotooildrainvalve.com/
The only thing I don't like about Fumoto valves is that you don't get all of the oil out when you drain it. There is still some left and that is where the crud collects.
Next time you change your oil, drain it all via the Fumoto. Now remove the Fumoto and see how much more oil comes out. You may be surprised.
I use NoSpill oil plugs. Made in USA and Canada, fit flush, drains to the last drop and can't get ripped out by road debris. Milled from brass bar stock; no crappy castings or nylon pivots. Drains hot oil into a jug through a hose. The police fleets here and the Navy use them. A big step above Fumoto and the Chinese knock-offs.
https://www.nospillsystems.com/products-parts.cfm
