Debating leveling kit.
Black
Kentucky
E
Eric B
waukesha
I been looking at all the different spacer lifts. Seems like the front only sizes differ. What size would I need to just level the front?
oldpaddy
Cape Cod
Does anyone know if there is a 1.5" front and 1" rear lift? Not looking for anything more than that so kids can still climb in easily. I found a 1.5" front spacer but I can't really find anything for the rear.
My 5 and 8 your olds get in and out just fine with the 3/2.
oldpaddy
Cape Cod
How long have you had the lift? Any problems or any other concerns yet?
About 9 months. I didn't have any worries until yesterday. Mechanic was working on my brakes, same one that installed my lift kit, and he said I should get the tuff country upper control arms. Said the lifts are putting too much pressure on the ball joints. Other than that I've had zero problems or concerns. I will note that the lift kit does change the ride smoothness a little. The ride is a little stiffer. But, I much prefer the added height and level ride.
Black
Kentucky
Being up north I would stay away from a uniball setup.
We get lots of ice here so lots of salt no way I would have uniballs on my daily driver.
I would suggest BDS as they use standard style but upgraded ball joint.
ICON with the Delta Joint would be the 2nd option but I can’t justify the added cost.
oldpaddy
Cape Cod
Any idea of the F150 BDS upper control arms will fit a '14 expy?
Black
Kentucky
Yup F150s share upper control arms with the Expedition back to 2007.
Just make sure not to get the Raptor model. Control arms for the Raptor are different.
Nice thing about BDS as well is you can get replacement ball joints later on.
Pretty sure they use a beefed up Moog ball joint.
E
Eric B
waukesha
BDS?
Black
Kentucky
The F150 and Expedition share a control arm.
A couple folks on here are using aftermarket F150 arms.
Bilstein will also tell you their F150 struts won’t work on the 15-17s but they work just fine.
It is a liability thing since they have not tested it.
Ragebuzz
Saudi Arabia
I want to get a 3" front and 2" back leveling kit. Should I get new upper control arms made for lifts?
oldpaddy
Cape Cod
Yes. I got bds upper controls arms. It's a tight fit, but they don't rub up against the springs.
