Rear Seat Interior Lights - Trick?
Super Moderator
Super Moderator
Alright...is there a trick to getting the rear seat interior lights out. Trying to swap to LED.
There doesn’t seem to be any obvious tab. This is the Driver side. I can see a tab on the right, that is hook in, but nothing on the left to pop...?
Looking for the trick.
Thanks!
Dannyboy11222
Brooklyn
See the hole in the front middle of the mold, use a poker to access it. Just take ur time and pull the one side down..
Sent from my LM-G710VM using Tapatalk
Super Moderator
Super Moderator
I don’t see a slot/hole/tab...hence the question. I have taken many interiors apart, but this one just seems like it has no give.
I went out and looked at mine and same thing no dice. Have you tried gently prying on it with something small?
Super Moderator
Super Moderator
I was trying to remove the whole assembly! Just the clear pic in a second. Gotta do the other side!
Super Moderator
Super Moderator
Trying to get just the clear center section. It then actually makes it far easier to get the whole assembly out. It releases the pressure on the hinge side.
Dannyboy11222
Brooklyn
Its really easy once you know what to do.., don't try to swap out the visors lights, I've tried and broke the glass and a wire... Its not worth it...
sharprd65
