2016 85k miles, transmission went out
5x10
Houston
Input rod broke, need replacement transmission
5k
that’s what I get for buying a ford
The cost to rework the Ford 6 speeds should come down, too much $$ when compared to competitors with the same ZF licensed 6 speed. The GM unit is a lot less $$ to overhaul and it’s basically the same thing.
oldpaddy
Cape Cod
Yikes. That's scary.
I remember when I owned a Chrysler 300. A year after the warranty ran out the engine and transmission died at the same time. I still had 2 years left on the note and I had switched jobs and was making a lot less money. I called up the finance company and told them to come pick it up. That killed my credit for 7 years. I'll never buy a mopar ever again.
It is very unusual for the engine and transmission to fail simultaneously - what happened to each?
oldpaddy
Cape Cod
I don't remember exactly. It was 9 years ago. My wife works at a mechanic shop and they diagnosed it. I remember the 300 smoking like a train from the 1800's and it not shifting right. I think I owed $10k and it needed $5k worth of work. Regardless, I decided at the time that it wasn't worth it. That's when I found my first expy for short money and instantly fell in love.
ManUpOrShutUp
That sucks. It would probably be my last Ford if the trans died at 85K and I had no warranty.
TobyU
Exactly why I chose to go find a clean low mile 03 when I bought my Navigator.
Not going with 3v or the 6sp trans when the other parts are so plentiful and cheaper.
You should still be able to get a plenty of trans that will fit yours in salvage yards or pick and pay lots.
I will NEVER pay to have a trans rebuilt or replaced UNLESS I pull it out and have a friend or someone who I trust who is cheap enough to rebuild it then put it back in myself.
The most cost effective way is to get a junk yard used good used one and swap it your self or even pay someone to swap if you can not.
This keeps the price decently down there.
A 5000 repair is not going to happen to any of my vehicles.
Better off to sell it or trade it in(which is evil too) but if you do the math ..... you would more than likely come out better in what you have in it and what it is worth than if you put 5k into fixing it.
I see you are in Houston. Should be TONS of people there wrenching on cars from craigslist and marketplace.
Find someone you know who has had good experiences with someone on the side and go buy a replacement trans (make sure it is right one 4wd, year period etc) and put it in the rear and tow it to him to swap.
Going rate on swapping a trans is 300-600. Only shops get into the 700-1200 labor range because they are crooks, ahem, greedy, ahem, because they can get by with it.....
Yep, I said it. All true!
The chances of the 6R80 breaking are still slimmer than the old 4 speed overall since it’s a lot more robust and band-less with less to go wrong. I thoroughly enjoy the 5.4 3V Triton/ 6R80 combo. The 6 speed woke this engine up over previous. Here is a Ford F-150 test run with the 4.6L 2V/4R70 vs 4.6 3V/6R80 on their test track.
jeff kushner
North of Annapolis
Horrible news 5x10......I'm assuming you mean the input shaft. That truly sucks but I think you just got your turn to be "that guy". The guy who gets a broken part that hardly no one ever gets. I would explore all options before making a decision IF you like your truck. If you don't, it's the perfect excuse to get rid of it. My '17(same as yours) just rolled past 85K, time will tell if I join you.
Sucks as this time of year for a lot of folks, even if it isn't a $$ issues, it's still a pita dealing with having to replace a vehicle during the holidays.
Good luck,
jeff
5x10
Houston
Good luck,
jeff
Yep, first time to be that guy
Also the first time I chose not to get an extended warranty
your right, the input shaft
I’m gonna keep it, $5k is a lot cheaper than the alternative of swapping vehicles out
Probably $20k+ difference in moving to a newer model(2018 expy) or to another brand
rjdelp7
2000 XLT
NY
I never heard if an input rod failure. Get a second opinion. The 6R80 goes nuts after a dead battery. Was there a battery problem recently?
5x10
Houston
No battery issues
my wife had just got done throttling it
Then it became unresponsive to throttle
TobyU
Breaking is a very vague word. I find it very hard to believe that a 6r80 will be a more trouble free transmission in the next 10 years vs a 4r75w or my personal favorite the 4r100.
I am certain there will be tons of common problems and common repairs needed for the 6-speed transmission in the future whether it be the valve body problems, Springs Breaking Inside accumulators etc. I really don't see them being a improvement over the previous transmissions in durability, longevity, or the absence of needed repairs.
The 6R75/80 is a better transmission than the 4R75 and 4R100. These 6 speeds have been out since 2006 the verdicts in, they are better, a lot better. Track record shows less problems and with no bands less issues.
5x10
Houston
What is "throttling it" ?
Accelerating
Turned onto a road, gave it some throttle to get up to speed
Then, the engine would rev but there was no response from the drive train
got it back to the house, didn’t matter what gear you put it in, no response from hittin the gas
rjdelp7
2000 XLT
NY
Front planetary graneded. You should have L1 or reverse, if it was something else.
TobyU
Hard to believe it's better than a 4r100. I'll let you know when the verdict is in when they are 15 to 20 years old and I have seen how many problems myself and my friends have had with them.
I stay away from things when they're newer because they will justify the high price of rebuilt and stuff but as they get older it will be easier to find them and Salvage Yards which you should already be able to find a good selection of them. I'm not a fan of them going to six. Because it's just over complicated and cost more money to fix or rebuild but once they're 10 to 12 years old everything settles back down to a normal level and they can rip people off on the next new thing that's out.
