Knocking on start up
Shantheman73
Kansas City
I’m sure this has been talked about but my search yielded no results.
2007 Expy Limited. When starting in the morning I get a fast knocking that goes away within a second or two. Only happens when cold starting it. What’s the culprit? Lifters? Cam phaser? Rotory girder? [emoji38]
2007 Ford Expedition Limited
I would check the basics first; correct oil level, correct oil viscosity, a high-quality oil filter, and length of time from last oil change (clogged oil filter?).
Not sure what a rotory girder is?
Could be piston slap, these engines use forged pistons which do that time to time when cold. Another likely possibility is you have an exhaust manifold leak as the studs are known to break off on the passenger side one. Listen close to the passenger manifold on a cold start and you’ll hear it if that’s the case.
Or is it more of a clattering or rattle noise? That would indicate timing chain tensioner seal starting to blow out and slack in the chain after sitting meaning a timing job may be imminent. For what it’s worth I had this but could not do the timing job this winter so I added some oil stop leak to my oil a few thousand miles ago and the startup rattle has gradually disappeared for the most part. This isn’t a permanent fix by my standards more of a time buyer.
Shantheman73
Shantheman73
Kansas City
Rotory girder is from Tommy Boy...classic Chris Farley.
iimagine
2016 EL XLT
That was my first thought. Check the oil.
Machete
My Rig. 2000 EB 4x4 5.4L
Illinois
That’s not good. The reason it only happens when cod and only a few seconds is delayed oil pressure. Oil pump! Maybe the rest of your VVT.
purevw
Assuming it's not piston slap or exhaust, I would agree that oil pressure delay is the culprit, but not necessarily the oil pump. I would guess that the check valve in the oil filter isn't' holding and the oil is draining back into the pan when it sits for a while. If you have normal oil pressure when running, then the oil pump is fine. Any brand of filter (including Motorcraft) can have an occasional manufacturing defect. The filter is cheap. I would try swapping it out, possibly with a different brand. Start the vehicle and give the filter time to fill. Then shut it down and refill the oil to the proper level. It may not take a whole quart.
Shantheman73
Shantheman73
Kansas City
Ok thank you for the input.
Last night I changed the oil and put a motorcraft filter on...it was still some off brand on there from when I bought it a few mo back. I’ll see if fresh oil and quality filter makes a diff.
Oil pressure has seemed fine so I’m hoping this does the trick.
Machete
Illinois
Get Kendal 1 synthetic w liquid titanium.
It’s made by the same company that makes motorcraft oil, ConocoPhillips.
Kendal has a far superior additives package at half the price. Use motorcraft filter.
My money is on the known issues w stock oil pump. Google it and see.
HawkX66
Semper Fi!
VA/MA
IMO it's the oil filter. My 07 5.4L w/ 215k on the clock was doing the cold knock here and there. Even after oil changes. I always used Motorcraft oil and filter from Wallyworld because it was the cheapest. I switched filter brands and what a surprise, not a sound. My guess is the backflow preventer in the filter is weak allowing the oil to drain out of the filter and top end. If you have a vertical mount filter like on a SBC or BBC, the backflow preventers don't matter as much. When the filter is horizontal like on the 5.4L they do matter.
07navi
Mt.Shasta California
Surely the timing chain tensioners leaking. The whole front of the engine has to come out to get to them and they are controlled by your oil pressure. They leak and then won't push on the chains to take up the slack but will when they pump up enough. I would have included a cheap oil filter that won't control back flow but that's not a cold weather only problem.
HawkX66
Semper Fi!
VA/MA
It's not a cold weather issue, it's a cold start issue. After it has been sitting and given enough time to let the oil drain back into the pan.
As far as the timing tensioners, they don't have to leak to not pump up. When I tore the motor down in my son's Mustang when we bought it, this is what the tensioner looked like. Previous owner didn't believe in oil changes apparently...
