Removing front air dam?
TexasDan
Expy FX4 skids bolt up on non FX4 Expy models.
After reading the above, and the comment about the lower bumper fascia being a little floppy with the air dam removed, I wonder if the Expy FX4 air dam, with the higher center clearance, is compatible with non-FX4 Expys. Anyone happen to know?
Thanks,
Dan
CertusExpo
Customizing trucks since I was 7 with my Legos
Fort Worth, TX
Depends on what generation Expy I suppose, or also how much is removed because I don't have any issues.
sjwhiteley
Kentucky
Thanks,
Dan
While I don’t know about the FX4 air dam, I’m sure it does move about a bit. I added a skid plate to the front; the lower fascia left rub marks on the skid plate from some obvious movement (lower fascia was in contact with the skid plate after solidly mounting plate).
You could probably cut down the air dam to almost nothing, and retain the rigidity.
scottdm
Western PA
Refer to post #5 in this thread to see what the front air dam looks like when cut down to about 1" while still maintaining the rigidity of the front lower facia.
sjwhiteley
Kentucky
Ha ha! I thought I'd seen that somewhere!
phorn73
Geneva, IL
I must be an idiot because I can’t figure out what size bolt head the small ones are. 5mm is too small 6mm is too big. Same with 1/4” and 3/16”. Also do the white clips need to be removed?
sjwhiteley
Kentucky
Apparently, it’s a 5.5mm according to some instructions I had. I used a 7/32” (which is most likely the size). That size is also used for the fender liner on the inside of the wheel arch - same screws used on the fender liner.
wakeboarder
Fort Lauderdale, FL
My vote is for the 5.5mm. I have seen them used in other applications. I thought all of the major automotive manufacturers hadn’t used SAE fasteners since the 80’s.
Edistobob
South Carolina
Definitely is 5.5 mm. When I removed the air dam, I bought one either from an auto parts store or the local hardware. None of the sockets I already had fit well enough.
sjwhiteley
Kentucky
That is true, this is the first time i've seen a 5.5mm head. 7/32 is 5.55mm. There must be a secret supplier of screws with this size head...
5280tunage
colorado
Not sure. But I had no issues with my 6mm, my guess is tolerances in tools are enough to make it fit or a little loose. I threw a 6mm on a handheld electric screwdriver and it worked great.
I did remove any of the clips that weren't needed, but j saved them for later if needed.
So far I have had no issues with noise or movement and unfortunately I've only driven city streets so I can't really say of there is a noticeable effect on mileage.
My biggest concern are the stupid huge open pockets that fill up with snow and slush, I really wish these were more closed off.
Peter L
Just finished having skid plates installed on my 2019 Limited; took the front dam off as well. Ordered a full set: front, transmission and differential from RCI Offroad in Loveland, CO (www.rcimetalworks.com). The whole package was $695 and I ordered the set for the 2015-2022 F150. FYI, they offer military discount as well. Installation by RSG Offroad in Lakewood, CO was about $400 and took about 2-1/2 hours. The plates went on with only minor changes and I think looks pretty good. Covers everything back to the gas tank. Everything else is pretty stock except for using Falken Wildpeak AT3. Great tires but dropped my mileage about 3 mpg.20211202_123129.jpg
sandyride
UAE
I tried to remove mine over the weekend, got the 4 bolts out but couldnt figure out for the life of me how to remove the darn thing the clips wont budge, is there a technique to removing them (i dont have a jack or lift so lying down and reaching under lol)....went into the dunes without the 4 bolts and drove on the streets luckily attached solid as a rock...
5280tunage
colorado
A good metal forked panel popper is what did the trick for me. I have an old snap on that works great.
