buffy
So, I'm running LT275/60R20 Yokohama tires measuring 33.3". Factory fitment is around 32". I love the look, the LT construction and the minor lift. I don't like that the MPGs went from 16.5mpg to 14.5mpg. These tires are 10#s heavier, and of course, taller. So what caused the drop. Could be the weight, but I suspect air underneath the truck. Putting on our engineering cap and reading the interwebs, I confirmed how simple front airdam design works. So I didn't have any problem finding something I could add to the bottom to extend the factory one down.
I used this: Trim-Lok DD1201-25 EPDM Dual Durometer Rubber/Metal Carrier Flap Seal, Fits Edge 0.050" - 0.090", 0.925" Flap Length
This is made from a EDPM rubber. Super flexible. It can take a lick. Steel wire core.
You get 25' of it. It's expensive @ $64.20, so you might want to convince a few friends to give it a try with you. I used stainless #8 screws with painted black tops to secure them to the HDPE air dam. The seal goes on good and tight, but you need the screws to keep it on if you drag over something.
The results? 16.0mpg
I didn't get all of it back, but enough to make this worthwhile. Did I mention that I drive fast?
I made a little kit for a buddy of mine with a '13 Expedition.
