Do you hear any strange noise from the engine at idle ? Like a loss of oil pressure where you'd hear some clacking from the top of the motor. Make sure you run at least 10w-30 synthetic oil in it, not that 5w-20 BS Ford uses for corporate gas mileage figures. Other than that you can use a mechanical oil pressure gauge installed in the sender's location to read actual oil pressure. Did you get any maintenance records with the Expy when you bought it ? Running a 10w-30 or 10w-40 oil in it, if you still have true low oil pressure it could be anything from a failing oil pump to a completely trashed engine.
