SomeENG
Los angeles
I have been having a "snapping" or "slapping" type noise that seems to come from the rear end when I get to 30MPH and seems to go away by 40MPH.
It isn't constant, it may only happen when driving straight or at a slight turn etc.
Maybe I just can't hear it over the road noise at higher speeds.
I have only noticed it after getting pretty aggressive mud tires on the back
These here
Eldorado Mud Claw Extreme M/T LT235/85R-16
Part#: MCX17
Price: $112.96
I did check the driveshaft by gripping it and trying to turn it back and forth to check for looseness and I don't see anything else loose.
Can aggressive tread make a snap, crackle, or popping noise on pavement?
I think I figured it out, I think the treads are super deep and picking up lots of rocks and throwing them into the wheel wells after driving off-road.
I've only ever used all terrain tires so I've never had so many rocks stuck in my tires so far from where I'm offroading, haha.
After about four miles all the rocks that have collected are ejected, and the noise stops.
It really did sound like bad ujoints or something.
Eddie1965
Culver City
Installed the autostop eliminator; only had my car for just under 2 months and couldn't take it anymore.
ManUpOrShutUp
My climate control ran like shit when my tstat was opening at 185F. I can't imagine what it will do at 160F. :x I'd also be surprised if the truck ever even reaches operating temp. These engines don't run hot at all (unlike my wife's Honda, which would probably benefit from a stat with a lower opening temp).
Blksmk
Canada/USA
I'll be towing alot starting on the 1st of June. Figure might as well give this a try..
Blksmk
Canada/USA
Keep us posted. I'm curious.
I'll be data logging . Got a 1978 27 ft travel trailer.
Taking it up to Alaska and once covid is done cross Canada trip.
I'm looking at efans bigger radiator and opening the exhaust bbk throttle body and aftermarket manifolds with a tuner.
Drove down in Manhattan and Brooklyn. Helped move my cousin out of Fordham University dorms. I found driving in NYC you just have to be aggressive and not let anyone know your move and it was pretty easy. If you sit there and react slow though you will never get anywhere lol. It also helped with corona traffic wasn’t bad. This was my first time to NYC, I stopped at Peter Luger and picked up some beef...was totally worth the bridge wait. Amazing. The guys who worked at Fordham seemed to be amazed about full size SUV ownership and thought it was pretty cool we can own these in the Suburbs. When I pulled up they had lots of questions about the truck lol. I saw two other EL’s in Manhattan.
Blksmk
Canada/USA
Rebuilt the t76mm turbo and ordered 60 lb injectors
Intake showed up got it in
heston gee
Madison, SD
Cried. 2 not so costly repairs, rear wiper pivot, door check assembly. Then...
Possible driver side blend door, I though I was done with the $1000 repairs.
