2003XLT. I have a power steering pinion leak at boot end. This BEATER is way too rusted to try to repair so the general consensus seems to be add the Lucas Stop Leak product and monitor ps fluid level to keep between the lines. Owners Manual says use Motorcraft Mercon ATF QT-2-QDX. I'm not see'ing that for sale so is Mercon V QT-5-QMC the stuff to use now? If I do that , can I just mix whatever is in there (who knows after all these years)? Can I add as much as I want of the Lucas Stop Leak in place of the Mercon whatever. It's only low a bit so I think the bottle of Lucas is going to keep it going for a while unless the leak gets much worse (which it won't since Lucas will put the kibosh on that). Maybe I should be turkey baster sucking some out of reservoir so I can add more Lucas product than the piddling amount it would take to bring up to ***** at the moment?
thanks for the help
thanks for the help
