Heavy Duty Radiator upgrade
Offwego
Denver
I have a 2017 Expy and like many others was told it had the HD towing package which it does not. I added the trans cooler and factory brake control but since I tow in the mountains have had several instances where the temp still gets too hot. Ford will only tell me that I have the standard cooling radiator CL3Z-8005 A. Has anyone swap the standard out for the HD CL3Z-8005-B? And was id a direct swap or were other parts needed?
O
Offwego
Denver
Thanks. I've searched everything I could find her and everywhere else I could think. Sometimes the F150 site has good info for us Expy owners. Learned how to program the factory brake control module there. I just ordered the HD cooling radiator and will see if it will just be a swap. If anyone is interested I will post the results.
Bigfishfin
Wenatchee, WA
Please do share your experience...I also have an Expy WO tow package and I added what I could to make the conversion. When I investigated the supposedly HD radiator the part numbers got squirlly and I could not get a clear understanding that there really was a HD radiator or not. I suggest you check every way you are able to determine if your new part is any different from your stock radiator. Thanks!...
07navi
Mt.Shasta California
Others have confirmed in here that the HD one is thicker.
Bigfishfin
Wenatchee, WA
I have not read a post making that claim, please direct me...The specs indicate 1 quart more capacity, but same fin count... I am probably wrong, but for the first time in my life?...
Langer
Chicago
One thing that really makes me question whether the HD Tow radiator is different, is that our non-HD tow radiators have the bracket on the front already built in, just waiting for the factory trans cooler to be put on. Why would that be there if there is another physically different radiator for the HD Tow package that has the trans cooler, too. I know logic cannot always be followed when it comes to automakers/engineers, but seems questionable, at least.
Bigfishfin
Wenatchee, WA
During the time of my upgrades as mentioned, I did conduct various searches, without success, regarding the HD radiator. Thanks for the assist?...
chuck s
There was a discussion on this subject 10 -12 years ago. There is a specific HD radiator which is thicker (front to back) but I don't recall how much. Same height and width and probably number of rows. Back then I was able to read the part number off my '07 HD radiator. But, alas, my saved photos from that era are hiding deep inside one of my hard drives. This was, of course, the 5.4V8.
The '07 part number may still work and may be a good starting point. There may still be messages here from the era.
I was curious about towing my 6000 pound travel trailer across the Pennsylvania turnpike thru what passes for mountains there for several years while my daughter attended college there. I had a data acquisition device plugged into the OBD2 port and the engine coolant graph was a literal flat line just below 200°F after the engine warmed up, rarely exceeding that temperature. The transmission temperature fluctuated with loads and shifting. Cylinder head temperature rose on the mountain grades but the coolant stayed in that 200 +/- a few degrees. (Auxiliary OBD2 gauge to read cylinder head temperature.)
-- Chuck
outdare
You can look at Mishimoto radiators. They make performance aftermarket parts for F150's and expeditions. Not sure is they have a direct replacement, but may have a solution.
Also you can call 5 star tuning I think they are a sponsor here. I believe the 14 F150 will fit our 2017 expie's.
https://5startuning.com/product/201...-performance-aluminum-radiator-mmrad-f150-11/
Sent from my moto g(7) play using Tapatalk
Bigfishfin
Wenatchee, WA
Thanks for the info regarding performance radiators!...But, the OP was discussing a stock Ford HD radiator for the Espy and several (including me) question the existence of such an animal...BTW, I have never experienced overheating with my 2015, going up mountain passes in up to 90+ temps, pulling my 4,900 GVW trailer (6,000+ LB. loaded) and others have shared similar realities. Possibly the OP has a problem other than the radiator?
chuck s
The HD radiator exists.
Note Post #11. I personally confirmed the HD radiator in my '07. The old thread may have comparison photos of the standard and thicker HD version.
Still shows as part of Option 536 (HD Tow) on my 2017 as it did on my '07. See page 16 of the 2017 Trailer Towing Guide. Option 536 is, I believe, included in higher trim packages so "having no problems" is certainly possible 'cuz the HD parts are already there. :)
-- Chuck
Bigfishfin
Wenatchee, WA
That is part of the mystery in that I have a XLT WO tow package, but with the auxiliary transmission cooler bracket on the stock radiator. Waiting to hear back from OP as to difference from the supposed HD radiator he is waiting to be delivered...I love mysteries!...
chuck s
According to the Towing Guides (plural) the 7-pole connector at the rear of the Expedition is only included with HD Tow 536 option (that option is standard on the Navigator and high trim models). This will be to the right side of the tow bar receiver; the 4-pole boat trailer connection is on the left. Easy way to identify HD tow on the Expedition the past 13 years, just look at the back bumper..
-- Chuck
mossback
2017 Limited EL
WA state
Looking at the Ford towing guide for the 2017 does seem to indicate two OEM radiator options.
Bigfishfin
Wenatchee, WA
Not to be a smart_ss, but if the factory says it, it must be so? My point is that I have seen no conclusive evidence that there is in fact a HD radiator. As noted by Langer earlier in this thread, the standard radiator has an auxiliary trans cooler bracket, (why) if there is actually a HD radiator which would of course be expected to have such an attachment...Don't believe Ford would spend $1.00 where not required...But, I could be wrong?...
PS: Just a thought, but could adding an auxiliary trans cooler to a standard radiator be construed to be a "Radiator Upgrade"?...Manufactures do "play on words" all the time...
07navi
That would be a risky play on words. I saw a post lately where someone said there was an extra row on the HD one but I don't remember who it was.
Bigfishfin
Wenatchee, WA
Interesting how some on this thread feel a need to defend the manufacturer...I don't know the answer, but I am just naturally curious when things don't quite add up...Just posing questions...
