Passenger wiper blade not going all the way down
Trey Salsbury
WI
Curious if anyone else out there has an issue with their wiper blades not returning to the heating element? The driver side seems fine but the passenger side needs to go down about another inch or two. Does anyone know if there is any type of an adjustment to bring it lower? Thank you
aggiegrad05
North Texas
Several folks have (check out this thread: https://www.expeditionforum.com/threads/windshield-wiper-de-icers.42973/) altho I’m not sure that anyone ever came up with a solution.
Fozzy
Riverton
If the window is dry it will not return to park. But after driving it the wiper will slowly move down. Window is wet it will make it back to the park position. I have tried to move the wiper one notch over and then it hits the windshield cowl. I have turned off the curtesy wipe and that seems to help. 3 wipes on the dry window and it will park well above the sticker.
MHay
These wipers are garbage. Mine get stuck in the middle of the windshield when driving if there’s not enough lubrication (i.e. water) on the windshield. Yesterday I was driving home from camping with our 30ft. trailer in the rain and the wipers stopped working altogether. Tried turning off and on multiple times and even tried the washer fluid button hoping they’d wake up. Had to pull over and then they finally started working again. I’d be happy if my only issue was the wipers not returning to the heating element!
