texasscot
This.It needs more than an adjustment. Check everything carefully. Something is worn, bent or broken.
I’d disconnect the tie rods, take off the boots on the steering rack, measure and center everything. Then see where the steering wheel sits. Then you could work out if it’s been taken off and put on clocked wrong or if the rack is off center.
Personally I wouldn’t drive it on a public highway until the problem is understood and known to be safe. Just my humble thoughts!
