That drivetrain shudder you feel? Yeah, it might be something else.
NukeLife
Charlotte
Having had the transmission main valve body replaced, and IWE actuators replaced, I am probably paranoid about drivetrain issues. (Prior to the valve body replacement my tranny was attempting to downshift to FIRST gear when I punched it on the interstate!) Recent threads about problems with rear differentials and front differentials prompted me to get my 2018 into the dealer (no appointment) to investigate a shudder that I have been noticing more and more.
MY symptoms: a shudder when applying LIGHT accelerator pedal—400 horses will mask this if you just mash the accelerator like a Neanderthal. This occurred in any gear, at any speed, and was more prevalent when going up grades (long hills, or driving into the mountains).
The kicker is, it wasn’t always there (of course), and seemed slightly more noticeable in 4A vs 2WD. Definitely more noticeable in 4A/Sport mode.
After recently towing, it was obvious the problem was becoming worse, and towing a load made it so obvious even the “tech” at the dealership couldn’t deny it.
So I hooked up a 14 foot enclosed cargo trailer and headed to the dealership to see David—the transmission guru. He was familiar with my Expy already, having diagnosed and repaired the valve body issue and IWE’s.
With me just driving up (no appointment), David came out to greet me,..listened to my concerns—and laughed when I told him I had a trailer hooked up ready to go in the parking lot.
Amazingly, he just chuckled and said let’s go take her for a spin. (Small town dealership)
Down the interstate, and back up through local roads, David put her through the paces (immediately aware of the shudder), thoughtfully listening to all the sounds with the windows down. Then he looks at me and says “I think I know what your problem is, but I can’t tell you because you probably will think I’m crazy, so we’ll just go back and I’ll see if I can prove it to you.
As we approached the dealership, he starts to talk about how, years back, he used to get all kinds of trucks in with “transmission problem” symptoms with the old 5.4 Tritons, and nearly all of them turned out to not be a mechanical drivetrain issue at all….
…as soon as he said that my jaw dropped, and I knew. He paused, and I blurted out an expletive or two followed by the words “@#$ing coil-on-plug!”
Yep. He got a good belly laugh out of hearing about my exploits with phantom misfires in my old F150, and eventually of course, me finding out about the well-documented issue with the coil-on-plugs (COP) in the 5.4 Tritons. I replaced four over the lifetime of my F150. So you’d think I would recognize a misfire, right?
Sure enough, he brought his laptop out and hunted around in MODE6 for pending codes and found cylinder #1 misfire. Fords are notorious for not locking in a CEL for misfires unless it gets so bad it’s a complete failure to fire. I felt pretty foolish, but also relieved I didn’t have a more difficult problem.
So, at his recommendation, I started with just the plugs. I bought 6 Motorcraft plugs from the Parts counter went home, and replaced them the next morning. I carefully inspected the COPs, the boots, and the old plugs as I removed them. None of the plugs looked bad, but #1 plug gapped at .033”, while the others all gapped .029-.030. The electrical connector at the top of the COP showed some light carbon buildup in only the #1 location also.
i cleaned everything up, and reassembled, while swapping the #1 and #2 COPs. Figuring if I continue to experience symptoms, I can scan to see if the misfire moved to #2 cylinder — and I’ll know it is a bad coil.
That’s been 2 days ago, and it runs as smooth as butter—no stumble, no shudder. I’m keeping my fingers crossed but it appears David was spot on.
JamaicaJoe
Oviedo FL
I would replace the boots and springs along with any new plugs. They get carbon tracks and will arc over with the slightest humidity. I probably need new plugs on my 2001 with 45K on the second set. I have been "fixing" mode 6 misfires with new boots.
I have a ScanGuage with mode 6 codes for all cylinders plus the LM1 monitor. If the LM1 spits out a number then you can be sure a plug has just misfired. Usually it is small like 81 count. But you will notice a stumble about half the time, but usually not.
Deadman
80,000 miles. Plug replacement at 100,000 per factory recommendation.
Sounds about right. Often a lot of very short trips and moving vehicles by just starting them up quick and shutting them down are hard on the plugs.
NukeLife
NukeLife
Charlotte
Being a 2018, the boots were still as new looking and feeling. I did apply a thin layer of silicone dielectric grease on the inside of the boots.
No evidence of carbon tracking on the plugs at all.
JamaicaJoe
Oviedo FL
My 2001 had plugs with wide, 0.80 gaps at around 38K. The 100K expectation is a fiction.
Once the misfires start, the boots get zapped. Don't count on seeing tiny tracks. Replace the plugs, replace the boots or you will have humidity iinduced misfires.
NukeLife
NukeLife
Charlotte
That’s a good thought. I will pay close attention the next time I drive in the rain.. and go ahead and order some boots to be safe.
5x10
Houston
My 2016 had that shudder before I traded it in
You described it to tee
I did have the plugs done, as it would go into low power mode
I want to say the boots were replaced as well but I am not certain
That was around 60-70k miles, I traded it just under 100k
ROBERT BONNER
Denver, NC
I worked at Ford for 23 years and never would have imagined that they could be so wrong on some of their service intervals; but, experience with my personal fleet has taught me the following to avoid issues like this:
Spark plugs in Compressed motors (supercharged or turbocharged) get replaced along with boots and springs at 45-50K. Naturally aspirated at 60K.
LV and ULV transfluid gets rotated by dropping the 4-6 quarts you can get out of the pan every 30K so that it has been substantially replaced by 90K. Otherwise full change at 80K.
Full synthetic motor oil and filter at 5K or 6 months....the filters are simply too small to go as long as the computer says even if the viscosity will hold up (which is unlikely with the turbos).
Never keep anti-freeze in for more than 5-6 years regardless of mileage.
Lots of Ford manuals say plugs will go 100K....Not the way my family drives. Some manuals say the transfluid will go 150K. Don't try it. The fluid will break down long before that resulting in a loss of shear strength leading to slipping clutches and other issues....
Just saying....
Deadman
Just saying....
I agree!
sjwhiteley
Kentucky
I suspect a lot of the high-mileage requirements (sic) are to not scare off those leases or those who buy vehicles for 2-3 years then trade. If you have, say, a 36k replacement on a maintenance part you are eating into that 3 year buyer, who doesn’t want that expense at the end, or suffer a potential hit in trade in value because they didn’t do it, along with the fact that things fail earlier than expected.
much like a laughable ‘lifetime warranty’ on pretty much anything.
Schini
Chesapeake
I came across this post and wanted to share a similar experience. I had a drivetrain shudder that was driving me insane. My vehicle is a 2018 Expedition Max Platinum (22"/CCD) that I bought used in Feb 2021 with around 42k miles on it. A couple months after purchase the ride was just horrible... and everyone at ford said it was normal. Multiple tech rides, etc. I was scratching my head between CCD issues, tire issues, transmission, turbo... you name it. I ended up changing my plugs (ensuring the gap was correct even though they were pre-gapped) after reading this post and sure enough that did it. I am at 50,000 miles and surprised the plugs went bad so fast but they are an easy change and this made a world of difference! Thank you!
DWs-TTEB
Evans, GA
Did you use Motorcraft plugs for the replacements?
lv2drive
PA, USA
i too am starting to get a “slight”
intermittent hiccup - (different from the trans hiccup between 3&4 while cold with gentle throttle slight incline as it seems to struggle to find 4th)
now wondering if i need to get the plugs done. 43k sounds like it might be that - i know i should do the boots too at the same time -
+1 on the motorcraft plugs question /
do we think the plugs are not up to ***** & we should throw different (better) ones in there, or would it not matter? with all the shortcuts i wouldn’t be surprised if this is one of them - i don’t believe the plugs are covered on any of the extended warranties if i am not mistaken?
Deadman
every time I stop, mine shudders and almost dies, I'm sure the spark plugs are gone. Its got 27,000 miles on, but lots of short trips.
FlyBry
Dallas, TX
5 Star Tuning sent me 6 of the Ford Motorsports CYFE-092-YPT3, 1 heat range colder, same plug in the 2019-20 Ford GT
NukeLife
NukeLife
Charlotte
Very happy to hear my story was able to help someone! And it amazes me that your tech rides never noticed the misfire.
FWIW, I still am running smooth with new Motorcraft plugs. I did not replace the boots or any COPs, yet. But I probably will just as a preventative measure.
