2003 Ford Expedition 5.4 EB 200K miles. strong crank with no start. New fuel pump, maybe a ground ?
David Carelli
canfield ohio
Hello, 03 expi EB 200K miles. Pulled in driveway at night, car runs perfect. In the morning, strong crank with no start. I sprayed starting fluid in throttle body and it starts briefly, so i suspected bad fules pump or fuel pump relay. I jumped the green yellow wire and got no action to fuel pump. So i thought ifound the problem. Bought a new pump and repladed. THAT WAS ALOT OF FUN !!! But didnt fix the problem. I then jumped the inertia switch and that didnt help. I believe now the relay is all that is left. But i am thinking it has to be a ground somewhere, as i jumped the relay and it doesnt engage the NEW fuel pump so i have to have a problem in the grounds somewhere. I can sure use some ideas ! Also, i have been searching the internet for awhile and cannot locate a chart of the grounding locations for a 2003 Expi. Anyone have a chart ? And is there a specific ground that controls the fule pump ?
D
David Carelli
canfield ohio
Thank you very much for the reply. Question, i ran a 12V jumper directly to the fuel pump Green yellow wire taking the relay out of the picture and the fuel pump still didnt run. And i am getting 12V coming into the green yellow wire. Doesnt this take the fuse box out of the picture as an issue. I also jumped the rear inertia switch. So i am thinking its a ground somewhere. But i cant locate a ground chart anywhere for a 2003 expi. Thanks again for the reply.
BlackCoffee
SOMD
It could be a few different causes. Before jumping at the fuel pump, I would put a fuel pressure gauge on the fuel rail and see what you get. 35-50 PSI is the working range. Pressure gauges are cheap and hooking to the Schrader valve is easy. If it cranks, you are getting power to the starter, but there are several other relays that may cause you a problem. I would diagnose the fuel pump first. If you have no pressure, you do not need to start running circuits.
D
David Carelli
canfield ohio
Thanks for the reply. Did not check the pressure yet because i did not hear the fuel pump coming on, and when i sprayed starting fluid into the throttle body it starts briefly. Also jumped the Green yellow from the relay with 12v still with no start, So i assumed bad fuel pump and just replaced it with a new one. All that work to drop the tank was disheartening when i tried to start it after and would not start. I just bought a new fuse box and will give that a try, but i am assuming it may not work since i jumped the relay out of the picture. I am leaning towards a ground or continuity issue but i cannot locate anything online for a 2003 expi ground locations.
Johnathan M
Klingerstown, PA
Prior to my current Expedition, I had a 2005 with the 5.4 liter. At one point I had fuel issues that drove me nuts as well. I replaced the fuel pump twice (Only pulled the tank once, because the pump didn't run when I plugged it in, so I replaced it before putting the tank back up), thinking I got a defective one. Finally realized I wasn't getting a ground at the pump. So I ran a ground from the frame (drilled a hole in the frame near the tank, and installed a screw to attach the ground) and tied it into the ground wire going to the pump. Problem solved for probably a couple months. One day on my way home it quit on me again. Got it home and started checking things out and now I didn't have power to the pump. I finally figured out that theres a module behind the driver side rear wheel up on top of the frame. It's a square box maybe 3" x 3" x 3/4" thick. I forget what it's called but all the power and ground for the pump run through that box before it goes to the fuel pump. They have a problem corroding internally, especially if the vehicle lives in an area that gets salt on the roads in the winter. What happened was that it had corroded internally enough that the ground was no longer connected, and so when I ran a new ground to the pump, it fixed the problem temporarily. Eventually, it corroded enough that the power supply was also cut off and the pump quit working again. Once I replaced that part, my problem was permanently solved. I suspect that there's a high chance that is your problem. Hope this helps!
Johnathan M
Klingerstown, PA
If you can't find a ground chart, you could just try tying a new ground into your fuel pump wiring just to see if that makes it run.
D
David Carelli
canfield ohio
Yes, thanks for the reply. Sounds like a great idea. My inertia fuel shut off switch on a 2003 is in the inside rear quarter panel. I jumped that as well with no luck. I bought a new remanufactured fuse box and will try that first. Then try a new ground.
Johnathan M
Klingerstown, PA
You're welcome. Just to be clear, I wasn't talking about the inertia fuel switch when I mentioned the location behind the driver side wheel, up on the frame. That's a different component called the fuel pump driver module.
D
David Carelli
canfield ohio
Ahhh... Yes, on the 2003 that is built into the fuse box. I still cant believe with all the guru's on the site, no one can tell me where the ground is located for the fuel pump.
D
David Carelli
canfield ohio
Thank you sir. Well its running !!!! I changed the fuse box and it started right up. Confusing though as i jumped the relay and it didnt run the fuel pump. So i changed the Fuel pump and nothing, but started after the fuse box change. On the back of the fuse box, lower forward connection there is only one wire running to the connection but it had come apart. I wonder if that was it. Any one know what the connection on the backside lower forward with only one wire is for ?
texas
probably a bit late for the post, but your problem may be with the central junction box which is a fuse and relay panel located on the passenger side front wheel foot well. It is the relay for the fuel pump on the 2003 in 2004 models exclusively. The replacement panel is now an obsolete part due to the age of the vehicle but there is a company in Boca Raton FL called vintage parts warehouse that has them available for the low sum of $410. You will need to look at the vin number in order to get the correct part because they change it up during the production year of 2003
Dadslilhelper
jacksonville FL
Very late reply as I am a newbie to this forum, I had this same problem after I blew thru 3 fuel relays for the fule pump it was infact burnt out on the inside of the PCM board. Now if your really savy they say you can re solder the interior relay but thats above my pay grade. I eventually got another PCM board from LKQ for $299 it was all plug and play in some cases you may have to get the truck reprogramed by a dealer to ensure everything works as it should ive read where when people do the swap it will drain the altinator ect. Mine just went in plug and play and no more issues.
Hamfisted
Ft Lauderdale
No programming required. But a brand new fuse box is about $350 from Ford. The fuse boxes are year and date of production specific though.
